Results 1 to 10 of 12
Thread: Looking for source code from Kilobaud Magazine.
    4,728
    Default Looking for source code from Kilobaud Magazine.
    Does anyone know of a source for source code presented in Kilobaud or Microcomputing magazine? While I could retype it, the online copies are a challenge to read.
    The actual article I am looking for is David Cortesi's text editor written in IBM BASIC. If you know of another short simple text editor or word processor written in IBM BASIC, please mention it.
    Dec 2005
    Toronto ON Canada
    7,350
    What issue/page #s?
    4,728
    January 1983 pages 64, 66, 69, and 70. Other pages between are ads. Title is " IBM's MVP (Most Valuable Program)"
    Mar 2013
    Chaffee, MO
    1,460
    I grabbed the PDF pages and OCR'd them with Irfanview using the plugin KADMOS. There may still be a few typo's.
     100 '************** THE STOPGAP EDITOR IN IBM BASIC ******************
     110 '         ***** by D.E. Cortesi
     120 DEFINT A-Z : MAXL = 300 : MAXW = 79 :' MAXW=40 FOR COLOR TV
     130 GOTO 1490
     140 ' ::: right-arrow key: move cursor right
     150 IF SCOL=MAXW THEN RETURN
     160 SCOL=SCOL+1 : INSCHAR=FALSE : LOCATE SROW,SCOL,1,CSL : RETURN
     170 ' ::: left-arrow key: move cursor left
     180 IF SCOL=1 THEN RETURN
     190 SCOL=SCOL-1 : INSCHAR=FALSE : LOCATE SROW,SCOL,1,CSL : RETURN
     200 ' ::: tab key: jump right from one to eight columns
     210 S=((SCOL+8) AND (-8))+1 : IF S<=MAXW THEN SCOL=S
     220 INSCHAR=FALSE : LOCATE SROW,SCOL,1,CSL : RETURN
     230 ' ::: end key: go to right end of the current line
     240 SCOL=MAXW : INSCHAR=FALSE : LOCATE SROW,SCOL,1,CSL : RETURN
     250 ' ::: printable character, action depends on INSCHAR
     260 IF NOT LMOD THEN L$=LT$(LCUR) : LMOD=TRUE
     270 IF NOT INSCHAR THEN MID$(L$,SCOL,1)=CIN$ : GOTO 300
     280 CIN$=CIN$+MID$(l$,SCOL,MAXW-SCOL)
     290 L$=LEFT$(L$,SCOL-1)+CIN$
     300 PRINT CIN$; : IF SCOL<MAXW THEN SCOL=SCOL+1
     310 LOCATE SROW,SCOL,1 : RETURN
     320 ' ::: backspace: blank currrent character, move left
     330 if not lmod then L$=LT$(lcur) : LMOD=TRUE
     340 MIDS(L$,SCOL,1)=" " : PRINT " ";
     350 IF SCOL>1 THEN SCOL=SCOL-1
     360 INSCHAR=FALSE : LOCATE SROW,SCOL,1,CSL : RETURN
     370 ' ::: del key: kill current char, pull rest left
     380 IF NOT LMOD THEN L$=LT$(LCUR> : LMOD=TRUE
     390 CINS=RIGHT$(L$,MAXW-SCOL)+" " : PRINT CIN$;
     400 L$=LEFTS(L$,SCOL-1)+CIN$
     410 INSCHAR=FALSE : LOCATE SROW,SCOL,1,CSL : RETURN
     420 ' ::: if current line has changed, update the file
     430 INSCHAR=FALSE : LOCATE ,,1,CSL : IF NOT LMOD THEN RETURN
     440 FMOD=LMOD : LT$(LCUR)=L$ : LMOD=FALSE : RETURN
     450 ' ::: return the index of the next free line in L
     460 IF LFREE=0 THEN L=FALSE : RETURN :'NO FREE LINES LEFT
     470 L=LFREE : LFREE=LF(L) : LF(L)=0 : LT$(L)=LMT$ : RETURN
     480 ' ::: free the line whose index is in L
     490 LF(L)=LFREE : LFREE=L : LT$(L)="" : RETURN
     500 ' ::: forward one line in the file image
     510 GOSUB 430 : L=LF(LCUR) :' L=0 IF LCUR IS BOTTOM LINE
     520 IF L=0 THEN GOSUB 460 : IF L THEN LF(LCUR)=L : LB(L)=LCUR
     530 IF L THEN LCUR=L :' FALSE IF BOTTOM AND NO FREE LINES
     540 RETURN
     550 ' ::: backward one line in the file image
     560 GOSUB 430 : L=LB(LCUR)
     570 IF L THEN LCUR=L :' FALSE IF TOP LINE
     580 RETURN
     590 ' ::: enter key: cursor to left margin, then down
     600 SCOL=1
     610 ' ::: down-arrow: cursor down (data up, on line 24)
     620 Q=LCUR : GOSUB 510 : IF Q=LCUR THEN RETURN
     630 SROW=SROW+1 : IF SROW<25 THEN LOCATE SROW,SCOL,1 : RETURN
     640 SROW=24 : PRINT :' FORCE BLANK LINE, RETURN CURSOR
     650 PRINT LT$(LCUR); : LOCATE SROW,SCOL,1 : RETURN
     660 ' ::: up-arrow: cursor up (data down 23 lines, on line 1)
     670 IF SROW=1 THEN 710
     680 Q=LCUR : GOSUB 560 : IF Q=LCUR THEN RETURN
     690 SROW=SROW-1 : LOCATE SROW,SCOL,1 : RETURN
     700 ' ::: up-arrow on line 1: slide current line down 23
     710 GOSUB 960 : S=0
     720 WHILE (S<22) AND LB(T) : T=LB(T) : B=LB(B) : S=S+1 : WEND
     730 SROW=SROW+S : GOTO 1020
     740 ' ::: PgUp key: back up 23 lines, hold cursor still
     750 GOSUB 430 : GOSUB 960 : S=0
     760 WHILE (S<23) AND LB(T) : GOSUB 560 : T=LB(T) : B=LB(B) : S=S+1 : WEND
     770 GOTO 1020
     780 ' ::: PgDn key: ahead 23 lines, hold cursor still
     790 GOSUB 430 : GOSUB 960 : S=0
     800 WHILE (S<23) AND LF(B) : GOSUB 510 : T=LF(T) : B=LF(B) : S=S+1 : WEND
     810 GOTO 1020
     820 ' ::: Home key: go to left, then to top, then to bottom
     830 IF SCOL>1 THEN SCOL=1 : INSCHAR=FALSE : LOCATE SROW,SCOL,1,CSL : RETURN
     840 GOSUB 430 : GOSUB 960 : S=SROW
     850 IF SROW=1 THEN WHILE LCUR<>B : GOSUB 510 : S=S+1 : WEND
     860 IF SROW>1 THEN WHILE LCUR<>T : GOSUB 560 : S=S-1 : WEND
     870 SROW=S : LOCATE SROW,SCOL,1 : RETURN
     880 ' ::: control-a: go to top of the file
     890 GOSUB 430 : GOSUB 2240 : LCUR=Z :
     900 SROW=1 : SCOL=1 : GOSUB 960 : GOTO 1020
     910 ' ::: control-z: go to the end of the file
     920 GOSUB 430 : GOSUB 2240 : LCUR=Z : T=Z : B=Z : S=1
     930 WHILE LB(T) AND S<24 : T=LB(T) : S=S+1 : WEND
     940 SROW=S : SCOL=1 : GOTO 1020
     950 ' ::: find the lines now at the top(T) and bottom(B) of the screen
     960 S=SROW : T=LCUR
     970 WHILE (S>1) AND LB(T>) : S=S-1 : T=LB(T) : WEND
     980 S=SROW : B=LCUR
     990 WHILE (S<24) AND LF(B) : S=S+1 : B=LF(B) : WEND
     1000 RETURN
     1000 RETIJRN
     1010 ' ::: redraw the screen using lines from T to B
     1020 CLS : L=T
     1030 WHILE L<>B : PRINT LT$(L) : L=LF(L) : WEND
     1040 PRINT LT$(B);
     1050 LOCATE SROW,SCOL,1 : RETURN
     1060 ' ::: Ins key: toggle insert-character mode
     1070 INSCHAR=NOT INSCHAR
     1080 IF INSCHAR THEN LOCATE ,,1,CSL,1 ELSE LOCATE ,,1,CSL
     1090 RETURN
     1100 ' ::: control-o: split the file for bulk insertion
     1110 IF INSLINE OR LF(LCUR)=0 OR LFREE=0 THEN RETURN
     1120 GOSUB 430 : LINS=LCUR : LCUR=LB(LCUR)
     1130 IF LCUR THEN LF(LCUR)=0 : GOSUB 510
     1140 IF LCUR=0 THEN GOSUB 460 : LB(L)=0 : LCUR=L
     1150 INSLINE=TRUE : GOSUB 960 : GOTO 1020
     1160 ' ::: control-c: splice the file after bulk insert
     1170 IF NOT INSLINE THEN RETURN
     1180 GOSUB 430 : WHILE LF(LCUR) : LCUR=LF(LCUR) : WEND
     1190 LF(LCUR)=LINS : LB(LINS)=LCUR
     1200 IF LT$(LCUR)<>LMT$ THEN 1240
     1210 L=LCUR : LCUR=LF(LCUR) : LB(LCUR)=LB(L)
     1220 IF LB(L) THEN LF(LB(L))=LCUR
     1230 GOSUB 490
     1240 INSLINE=FALSE : GOSUB 960 : GOTO 1020
     1250 ' ::: control-d: delete the current line
     1260 IF LF(LCUR)+LB(LCUR)=0 THEN RETURN :'CAN'T DELETE ONLY LINE
     1270 IF LB(LCUR) THEN LF(LB(LCUR))=LF(LCUR)
     1280 IF LF(LCUR) THEN LB(LF(LCUR))=LB(LCUR)
     1290 L=LCUR : IF LF(L)>0 THEN LCUR=LF(L)
     1300 IF LF(L)=0 THEN LCUR=LB(L) : IF SROW>0 THEN SROW=SROW-1
     1310 GOSUB 490 : GOSUB 960 : GOTO 1020
     1320 ' ************ THE MAIN LOOP ******************************
     1330 CIN$=INKEY$ : ON 1+LEN(CIN$) GOTO 1330,1390,1350
     1340 'handle a special key (numeric pad, Ins, Del)
     1350 S=ASC(RIGHT$(CIN$,1)) : IF S<71 OR S>83 THEN 1330
     1360 ON S-70 GOSUB 830,670,750,1330,180,1330,150,1330,240,620,790,1070,380
     1370 GOTO 1330
     1380 'handle regular control or character key
     1390 S=ASC(CIN$) : IF S>31 THEN GOSUB 260 : GOTO 1330
     1400 IF S=>8 AND S<=13 THEN ON S-7 GOSUB 330,210,620,830,1330,600 : GOTO 1330
     1410 IF S=1 THEN GOSUB 890 : GOTO 1330
     1420 IF S=3 THEN GOSUB 1170 : GOTO 1330
     1430 IF S=4 THEN GOSUB 1260 : GOTO 1330
     1440 IF S=15 THEN GOSUB 1110 : GOTO 1330
     1450 IF S=26 THEN GOSUB 920 : GOTO 1330
     1460 IF S=27 THEN GOSUB 1630 : GOTO 1330
     1470 GOTO 1330
     1480 ' ************ INITIALIZATION *****************************
     1490 GOSUB 1520 : FSPEC$="" :' CLEAR ALL DATA AND SET UP
     1500 CLS : LOCATE SROW,SCOL,1 : GOTO 1330
     1510 ' ::: clear all variables, set up a null data array
     1520 DIM LF(MAXL),LB(MAXL),LT$(MAXL)
     1530 LMT$=SPACE$(MAXW)
     1540 FALSE=(1=2) : TRUE=NOT FALSE
     1550 LMOD=FALSE : FMOD=FALSE
     1560 CSL=12 :' CURSOR SCAN LINE -- MAKE 7 FOR COLOR TV
     1570 INSCHAR=FALSE : LOCATE ,,1,CSL : INSLINE=FALSE
     1580 FOR I=2 TO MAXL-1 : LF(I)=I+1 : NEXT I : LF(MAXL)=0 : LFREE=2
     1590 LCUR=1 : LF(LCUR)=0 : LB(LCUR) = O : LT$(LCUR)=LMT$
     1600 SROW=1 : SCOL=1 : LCUR=1 : T=1 : B = 1
     1610 RETURN
     1620 ' ************ GLOBAL COMMANDS ****************************
     1630 GOSUB 1170 : GOSUB 430 : GOSUB 960
     1640 CLS : LOCATE 10,1
     1650 PRINT "Command choices are..." : PRINT
     1660 PRINT "   1. SAVE the present file''
     1670 PRINT "   2. LOAD another file"
     1680 PRINT "   3. CLEAR the data buffer of all data"
     1690 PRINT "   4. QUIT and return to DOS."
     1700 PRINT
     1710 INPUT "Your choice of 1,2,3,4 ";CIN$
     1720 IF CIN$="" THEN GOSUB 1020 : GOTO 1330
     1730 CIN$=LEFT$(CIN$,1)
     1740 IF CIN$="1" THEN GOSUB 1800 : GOTO 1640
     1750 IF CINS="2'' THEN GOSUB 1930 : GOTO 1640
     1760 IF CIN$="3" THEN GOSUB 2070 : GOTO 1640
     1770 IF CIN$="4" THEN GOSUB 2100 : GOTO 1640
     1780 GOTO 1640
     1790 ' ::: the command is: SAVE
     1800 GOSUB 2180 : OPEN FSPEC$ FOR OUTPUT AS #1
     1810 GOSUB 2240 :'find the top and bottom of the data
     1820 'write all lines, deleting trailing blanks
     1830 WHILE A<>Z
     1840   L$=LT$(A)
     1850   I=MAXW
     1860   WHILE I>1 AND MID$(L$,I,1)=" " : I=I+1 : WEND
     1870   L$=LEFT$(L$,I)
     1880   PRINT#1,L$
     1890   A=LF(A)
     1900   CLOSE#1 : FMOD=FALSE : RETURN
     1920 ' ::: the command is: LOAD
     1930 GOSUB 2070 : IF NOT Q THEN RETURN
     1940 GOSUB 2180 " OPEN FSPEC$ FOR INPUT AS #1
     1950 'read up to MAXL lines, force all to MAXW bytes
     1960 WHILE (LFREE>0) AND NOT(EOF(1))
     1970   LINE INPUT#1,CIN$
     1980   L$=LMT$ : LSET L$ = LEFT$(CIN$,MAXW)
     1990   LMOD=TRUE
     2000   GOSUB 510
     2010 WEND
     2020 CLOSE#1
     2030 LMOD=FALSE : FMOD=FALSE
     2040 LCUR=1 : SROW=1 : SCOL=1 : GOSUB 960
     2050 RETURN
     2060 ' ::: the command is: CLEAR (or clear prior to LOAD)
     2070 GOSUB 2120 : IF NOT Q THEN RETURN
     2080 ERASE LT$,LF,LB : GOSUB 1520 : RETURN
     2090 ' ::: the command is: QUIT
     2100 GOSUB 2120 : IF Q THEN SYSTEM ELSE RETURN
     2110 ' ::: if the file has been changed, get confirmation
     2120 IF NOT FMOD THEN Q=TRUE : RETURN
     2130 PRINT : PRINT "The file has been MODIFIED...!"
     2140 INPUT "...are you SURE you want to do this (Y/N> ";CIN$
     2150 CIN$=LEFT$(CIN$,1)
     2160 Q=(CIN$="y") OR (CIN$="Y") : RETURN
     2170 ' ::: get a filespec for load or save
     2180 PRINT : PRINT "Give me a filespec";
     2190 IF FSPEC$<>"" THEN PRINT " (";FSPEC$;")";
     2200 INPUT CIN$ : IF (CIN$+FSPEC$)="" THEN PRINT : GOTO 2180
     2210 IF CIN$<>"" THEN FSPEC$=CIN$
     2220 RETURN
     2230 ' ::: find the top(A) and bottom(Z) lines of data
     2240 A=LCUR : WHILE LB(A) : A=LB(A) : WEND
     2250 Z=LCUR : WHILE LF(Z) : Z=LF(Z) : WEND
     2260 '..minus trailing, empty lines, if any
     2270 WHILE LT$(Z)="" AND Z<>A : Z=LB(Z) : WEND
     2280 RETURN
    Let me know how it goes. (You may need to change line endings from 0x0D 0x0A to whatever you need for your system.)
    1. Download the PDF.
    2. Print the specific pages (68, 73-74)
    3. use pdftk to burst the pages to single sheets
    4. Convert to TIF (using convert from Irfanview -- was 72 DPI now 300)
    convert -density 300 pg_0001.pdf -background white -density 8 pg_0001.tif
    convert -density 300 pg_0002.pdf -background white -density 8 pg_0002.tif
    convert -density 300 pg_0003.pdf -background white -density 8 pg_0003.tif
    5. Convert to 1BB (1 Bit Black) -- (I use RasterVect for this because I can experiment with settings for better conversion)
    6. OCR with Irfanview's Plugin KADMOS
    7. Save ASCII files, merge, and edit typo's.
    Thanks.
    Larry
    4,728
    My apologies. Completely missed that this was posted. Thank you. Few minor corrections like some of the dollar signs were turned into S but I should be well on my way to testing it out.
    34,370
    If it helps, I have a real copy of KB Issue 1, Volume 1.
    4,728
    Anything that was already prepared will be appreciated but please don't put effort into assisting me. I am just looking for a few simple business applications that I can hack down to run within the confines of Cassette BASIC creating an erstwhile Cassette Office. This is not a serious project; just something that might generate a chuckle.
    Mar 2013
    Chaffee, MO
    1,460
    I found the following typo's in the OCR'd file:
    280 CIN$=CIN$+MID$(L$,SCOL,MAXW-SCOL)
    330 if not LMOD then L$=LT$(LCUR) : LMOD=TRUE
    340 MID$(L$,SCOL,1)=" " : PRINT " ";
    380 IF NOT LMOD THEN L$=LT$(LCUR) : LMOD=TRUE
    390 CIN$=RIGHT$(L$,MAXW-SCOL)+" " : PRINT CIN$;
    1660 PRINT "   1. SAVE the present file"
    1750 IF CIN$="2" THEN GOSUB 1930 : GOTO 1640
    1940 GOSUB 2180 : OPEN FSPEC$ FOR INPUT AS #1
    There are probably more.
    Larry
    4,728
    I found a few more errors including a missing line caused by the OCR having the same line number twice. However, it seems to work completely and it runs under simulated Cassette BASIC. Thank you for the assistance.
    Here is a revised copy with all the mistakes I could find corrected, the addition of word wrap provided in a later issue, and a small message to clarify how to get out of the menu.
    130 GOTO 1490
    303 REM IF SCOL=> 76 THEN BEEP ' alert typist to end of line
    305 IF SCOL=> 72 AND CIN$ = " " THEN GOSUB 600 : GOTO 1330 ' word wrap
    307 IF SCOL = MAXW THEN GOSUB 600 : GOTO 1330 ' line wrap around
    330 IF NOT LMOD THEN L$=LT$(LCUR) : LMOD=TRUE
    540 RETURN
    580 RETURN
    600 SCOL=1
    710 GOSUB 960 : S=0
    770 GOTO 1020
    810 GOTO 1020
    890 GOSUB 430 : GOSUB 2240 : LCUR=A
    960 S=SROW : T=LCUR
    970 WHILE (S>1) AND LB(T) : S=S-1 : T=LB(T) : WEND
    980 S=SROW : B=LCUR
    1000 RETURN
    1020 CLS : L=T
    1040 PRINT LT$(B);
    1090 RETURN
    1230 GOSUB 490
    1370 GOTO 1330
    1470 GOTO 1330
    1610 RETURN
    1700 PRINT "      Press ENTER to resume editing."
    1780 GOTO 1640
    1830 WHILE A<>Z
    1840   L$=LT$(A)
    1850   I=MAXW
    1870   L$=LEFT$(L$,I)
    1880   PRINT#1,L$
    1890   A=LF(A)
    1900 WEND
    1910 CLOSE#1 : FMOD=FALSE : RETURN
    1973 REM FOR I = 1 TO LEN(CIN$)
    1975 REM IF ASC(CIN$) = 9 THEN MID$(CIN$,I,1) = " "
    1977 REM NEXT I
    1990   LMOD=TRUE
    2000   GOSUB 510
    2010 WEND
    2020 CLOSE#1
    2050 RETURN
    2220 RETURN
    2280 RETURN
    Mar 2013
    Chaffee, MO
    1,460
    I compared again with your updated version and found two more typo's in your update.
    Larry
