Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Looking for source code from Kilobaud Magazine.
    4,728
    Thank you. Seems that all the OCR induced errors have been corrected. I will finish off the thread with an updated draft once I correct what seems to be a coding error in the tab expansion code from the follow up article.
    4,728
    What follows should be the last update for this.
    Code changesne more S( changed to the correct $(; wordwrap set to line width variable instead of hard coded based on 80 character lines - if the code is designed to be modified to work on a TV, so should the word wrap; and the load file routine can check every character for a TAB and replace it with a space. The TAB fix is commented out; checking 24,000 characters will take considerable time on a 5150.
    For anyone that might use this, the allocation of lines should be reduced if running on different hardware. A 16K 5150 might only have room for around 50 lines. Exact value and testing of loading and saving on cassette will be contingent on running this on real hardware.
    100 '************** THE STOPGAP EDITOR IN IBM BASIC ******************
    110 '         ***** by D.E. Cortesi
    120 DEFINT A-Z : MAXL = 300 : MAXW = 79 :' MAXW=40 FOR COLOR TV
    130 GOTO 1490
    140 ' ::: right-arrow key: move cursor right
    150 IF SCOL=MAXW THEN RETURN
    160 SCOL=SCOL+1 : INSCHAR=FALSE : LOCATE SROW,SCOL,1,CSL : RETURN
    170 ' ::: left-arrow key: move cursor left
    180 IF SCOL=1 THEN RETURN
    190 SCOL=SCOL-1 : INSCHAR=FALSE : LOCATE SROW,SCOL,1,CSL : RETURN
    200 ' ::: tab key: jump right from one to eight columns
    210 S=((SCOL+8) AND (-8))+1 : IF S<=MAXW THEN SCOL=S
    220 INSCHAR=FALSE : LOCATE SROW,SCOL,1,CSL : RETURN
    230 ' ::: end key: go to right end of the current line
    240 SCOL=MAXW : INSCHAR=FALSE : LOCATE SROW,SCOL,1,CSL : RETURN
    250 ' ::: printable character, action depends on INSCHAR
    260 IF NOT LMOD THEN L$=LT$(LCUR) : LMOD=TRUE
    270 IF NOT INSCHAR THEN MID$(L$,SCOL,1)=CIN$ : GOTO 300
    280 CIN$=CIN$+MID$(L$,SCOL,MAXW-SCOL)
    290 L$=LEFT$(L$,SCOL-1)+CIN$
    300 PRINT CIN$; : IF SCOL<MAXW THEN SCOL=SCOL+1
    303 REM IF SCOL=> (MAXW - 3) THEN BEEP ' alert typist to end of line
    305 IF SCOL=> (MAXW - 7) AND CIN$ = " " THEN GOSUB 600 : GOTO 1330 ' word wrap
    307 IF SCOL = MAXW THEN GOSUB 600 : GOTO 1330 ' line wrap around
    310 LOCATE SROW,SCOL,1 : RETURN
    320 ' ::: backspace: blank currrent character, move left
    330 IF NOT LMOD THEN L$=LT$(LCUR) : LMOD=TRUE
    340 MID$(L$,SCOL,1)=" " : PRINT " ";
    350 IF SCOL>1 THEN SCOL=SCOL-1
    360 INSCHAR=FALSE : LOCATE SROW,SCOL,1,CSL : RETURN
    370 ' ::: del key: kill current char, pull rest left
    380 IF NOT LMOD THEN L$=LT$(LCUR) : LMOD=TRUE
    390 CIN$=RIGHT$(L$,MAXW-SCOL)+" " : PRINT CIN$;
    400 L$=LEFT$(L$,SCOL-1)+CIN$
    410 INSCHAR=FALSE : LOCATE SROW,SCOL,1,CSL : RETURN
    420 ' ::: if current line has changed, update the file
    430 INSCHAR=FALSE : LOCATE ,,1,CSL : IF NOT LMOD THEN RETURN
    440 FMOD=LMOD : LT$(LCUR)=L$ : LMOD=FALSE : RETURN
    450 ' ::: return the index of the next free line in L
    460 IF LFREE=0 THEN L=FALSE : RETURN :'NO FREE LINES LEFT
    470 L=LFREE : LFREE=LF(L) : LF(L)=0 : LT$(L)=LMT$ : RETURN
    480 ' ::: free the line whose index is in L
    490 LF(L)=LFREE : LFREE=L : LT$(L)="" : RETURN
    500 ' ::: forward one line in the file image
    510 GOSUB 430 : L=LF(LCUR) :' L=0 IF LCUR IS BOTTOM LINE
    520 IF L=0 THEN GOSUB 460 : IF L THEN LF(LCUR)=L : LB(L)=LCUR
    530 IF L THEN LCUR=L :' FALSE IF BOTTOM AND NO FREE LINES
    540 RETURN
    550 ' ::: backward one line in the file image
    560 GOSUB 430 : L=LB(LCUR)
    570 IF L THEN LCUR=L :' FALSE IF TOP LINE
    580 RETURN
    590 ' ::: enter key: cursor to left margin, then down
    600 SCOL=1
    610 ' ::: down-arrow: cursor down (data up, on line 24)
    620 Q=LCUR : GOSUB 510 : IF Q=LCUR THEN RETURN
    630 SROW=SROW+1 : IF SROW<25 THEN LOCATE SROW,SCOL,1 : RETURN
    640 SROW=24 : PRINT :' FORCE BLANK LINE, RETURN CURSOR
    650 PRINT LT$(LCUR); : LOCATE SROW,SCOL,1 : RETURN
    660 ' ::: up-arrow: cursor up (data down 23 lines, on line 1)
    670 IF SROW=1 THEN 710
    680 Q=LCUR : GOSUB 560 : IF Q=LCUR THEN RETURN
    690 SROW=SROW-1 : LOCATE SROW,SCOL,1 : RETURN
    700 ' ::: up-arrow on line 1: slide current line down 23
    710 GOSUB 960 : S=0
    720 WHILE (S<22) AND LB(T) : T=LB(T) : B=LB(B) : S=S+1 : WEND
    730 SROW=SROW+S : GOTO 1020
    740 ' ::: PgUp key: back up 23 lines, hold cursor still
    750 GOSUB 430 : GOSUB 960 : S=0
    760 WHILE (S<23) AND LB(T) : GOSUB 560 : T=LB(T) : B=LB(B) : S=S+1 : WEND
    770 GOTO 1020
    780 ' ::: PgDn key: ahead 23 lines, hold cursor still
    790 GOSUB 430 : GOSUB 960 : S=0
    800 WHILE (S<23) AND LF(B) : GOSUB 510 : T=LF(T) : B=LF(B) : S=S+1 : WEND
    810 GOTO 1020
    820 ' ::: Home key: go to left, then to top, then to bottom
    830 IF SCOL>1 THEN SCOL=1 : INSCHAR=FALSE : LOCATE SROW,SCOL,1,CSL : RETURN
    840 GOSUB 430 : GOSUB 960 : S=SROW
    850 IF SROW=1 THEN WHILE LCUR<>B : GOSUB 510 : S=S+1 : WEND
    860 IF SROW>1 THEN WHILE LCUR<>T : GOSUB 560 : S=S-1 : WEND
    870 SROW=S : LOCATE SROW,SCOL,1 : RETURN
    880 ' ::: control-a: go to top of the file
    890 GOSUB 430 : GOSUB 2240 : LCUR=A
    900 SROW=1 : SCOL=1 : GOSUB 960 : GOTO 1020
    910 ' ::: control-z: go to the end of the file
    920 GOSUB 430 : GOSUB 2240 : LCUR=Z : T=Z : B=Z : S=1
    930 WHILE LB(T) AND S<24 : T=LB(T) : S=S+1 : WEND
    940 SROW=S : SCOL=1 : GOTO 1020
    950 ' ::: find the lines now at the top(T) and bottom(B) of the screen
    960 S=SROW : T=LCUR
    970 WHILE (S>1) AND LB(T) : S=S-1 : T=LB(T) : WEND
    980 S=SROW : B=LCUR
    990 WHILE (S<24) AND LF(B) : S=S+1 : B=LF(B) : WEND
    1000 RETURN
    1010 ' ::: redraw the screen using lines from T to B
    1020 CLS : L=T
    1030 WHILE L<>B : PRINT LT$(L) : L=LF(L) : WEND
    1040 PRINT LT$(B);
    1050 LOCATE SROW,SCOL,1 : RETURN
    1060 ' ::: Ins key: toggle insert-character mode
    1070 INSCHAR=NOT INSCHAR
    1080 IF INSCHAR THEN LOCATE ,,1,CSL,1 ELSE LOCATE ,,1,CSL
    1090 RETURN
    1100 ' ::: control-o: split the file for bulk insertion
    1110 IF INSLINE OR LF(LCUR)=0 OR LFREE=0 THEN RETURN
    1120 GOSUB 430 : LINS=LCUR : LCUR=LB(LCUR)
    1130 IF LCUR THEN LF(LCUR)=0 : GOSUB 510
    1140 IF LCUR=0 THEN GOSUB 460 : LB(L)=0 : LCUR=L
    1150 INSLINE=TRUE : GOSUB 960 : GOTO 1020
    1160 ' ::: control-c: splice the file after bulk insert
    1170 IF NOT INSLINE THEN RETURN
    1180 GOSUB 430 : WHILE LF(LCUR) : LCUR=LF(LCUR) : WEND
    1190 LF(LCUR)=LINS : LB(LINS)=LCUR
    1200 IF LT$(LCUR)<>LMT$ THEN 1240
    1210 L=LCUR : LCUR=LF(LCUR) : LB(LCUR)=LB(L)
    1220 IF LB(L) THEN LF(LB(L))=LCUR
    1230 GOSUB 490
    1240 INSLINE=FALSE : GOSUB 960 : GOTO 1020
    1250 ' ::: control-d: delete the current line
    1260 IF LF(LCUR)+LB(LCUR)=0 THEN RETURN :'CAN'T DELETE ONLY LINE
    1270 IF LB(LCUR) THEN LF(LB(LCUR))=LF(LCUR)
    1280 IF LF(LCUR) THEN LB(LF(LCUR))=LB(LCUR)
    1290 L=LCUR : IF LF(L)>0 THEN LCUR=LF(L)
    1300 IF LF(L)=0 THEN LCUR=LB(L) : IF SROW>0 THEN SROW=SROW-1
    1310 GOSUB 490 : GOSUB 960 : GOTO 1020
    1320 ' ************ THE MAIN LOOP ******************************
    1330 CIN$=INKEY$ : ON 1+LEN(CIN$) GOTO 1330,1390,1350
    1340 'handle a special key (numeric pad, Ins, Del)
    1350 S=ASC(RIGHT$(CIN$,1)) : IF S<71 OR S>83 THEN 1330
    1360 ON S-70 GOSUB 830,670,750,1330,180,1330,150,1330,240,620,790,1070,380
    1370 GOTO 1330
    1380 'handle regular control or character key
    1390 S=ASC(CIN$) : IF S>31 THEN GOSUB 260 : GOTO 1330
    1400 IF S=>8 AND S<=13 THEN ON S-7 GOSUB 330,210,620,830,1330,600 : GOTO 1330
    1410 IF S=1 THEN GOSUB 890 : GOTO 1330
    1420 IF S=3 THEN GOSUB 1170 : GOTO 1330
    1430 IF S=4 THEN GOSUB 1260 : GOTO 1330
    1440 IF S=15 THEN GOSUB 1110 : GOTO 1330
    1450 IF S=26 THEN GOSUB 920 : GOTO 1330
    1460 IF S=27 THEN GOSUB 1630 : GOTO 1330
    1470 GOTO 1330
    1480 ' ************ INITIALIZATION *****************************
    1490 GOSUB 1520 : FSPEC$="" :' CLEAR ALL DATA AND SET UP
    1500 CLS : LOCATE SROW,SCOL,1 : GOTO 1330
    1510 ' ::: clear all variables, set up a null data array
    1520 DIM LF(MAXL),LB(MAXL),LT$(MAXL)
    1530 LMT$=SPACE$(MAXW)
    1540 FALSE=(1=2) : TRUE=NOT FALSE
    1550 LMOD=FALSE : FMOD=FALSE
    1560 CSL=12 :' CURSOR SCAN LINE -- MAKE 7 FOR COLOR TV
    1570 INSCHAR=FALSE : LOCATE ,,1,CSL : INSLINE=FALSE
    1580 FOR I=2 TO MAXL-1 : LF(I)=I+1 : NEXT I : LF(MAXL)=0 : LFREE=2
    1590 LCUR=1 : LF(LCUR)=0 : LB(LCUR) = O : LT$(LCUR)=LMT$
    1600 SROW=1 : SCOL=1 : LCUR=1 : T=1 : B = 1
    1610 RETURN
    1620 ' ************ GLOBAL COMMANDS ****************************
    1630 GOSUB 1170 : GOSUB 430 : GOSUB 960
    1640 CLS : LOCATE 10,1
    1650 PRINT "Command choices are..." : PRINT
    1660 PRINT "   1. SAVE the present file"
    1670 PRINT "   2. LOAD another file"
    1680 PRINT "   3. CLEAR the data buffer of all data"
    1690 PRINT "   4. QUIT and return to DOS."
    1700 PRINT "      Press ENTER to resume editing."
    1710 INPUT "Your choice of 1,2,3,4 ";CIN$
    1720 IF CIN$="" THEN GOSUB 1020 : GOTO 1330
    1730 CIN$=LEFT$(CIN$,1)
    1740 IF CIN$="1" THEN GOSUB 1800 : GOTO 1640
    1750 IF CIN$="2" THEN GOSUB 1930 : GOTO 1640
    1760 IF CIN$="3" THEN GOSUB 2070 : GOTO 1640
    1770 IF CIN$="4" THEN GOSUB 2100 : GOTO 1640
    1780 GOTO 1640
    1790 ' ::: the command is: SAVE
    1800 GOSUB 2180 : OPEN FSPEC$ FOR OUTPUT AS #1
    1810 GOSUB 2240 :'find the top and bottom of the data
    1820 'write all lines, deleting trailing blanks
    1830 WHILE A<>Z
    1840   L$=LT$(A)
    1850   I=MAXW
    1860   WHILE I>1 AND MID$(L$,I,1)=" " : I=I+1 : WEND
    1870   L$=LEFT$(L$,I)
    1880   PRINT#1,L$
    1890   A=LF(A)
    1900 WEND
    1910 CLOSE#1 : FMOD=FALSE : RETURN
    1920 ' ::: the command is: LOAD
    1930 GOSUB 2070 : IF NOT Q THEN RETURN
    1940 GOSUB 2180 : OPEN FSPEC$ FOR INPUT AS #1
    1950 'read up to MAXL lines, force all to MAXW bytes
    1960 WHILE (LFREE>0) AND NOT(EOF(1))
    1970   LINE INPUT#1,CIN$
    1973 REM FOR I = 1 TO LEN(CIN$)
    1975 REM IF ASC(MID$(CIN$,I,1)) = 9 THEN MID$(CIN$,I,1) = " "
    1977 REM NEXT I
    1980   L$=LMT$ : LSET L$ = LEFT$(CIN$,MAXW)
    1990   LMOD=TRUE
    2000   GOSUB 510
    2010 WEND
    2020 CLOSE#1
    2030 LMOD=FALSE : FMOD=FALSE
    2040 LCUR=1 : SROW=1 : SCOL=1 : GOSUB 960
    2050 RETURN
    2060 ' ::: the command is: CLEAR (or clear prior to LOAD)
    2070 GOSUB 2120 : IF NOT Q THEN RETURN
    2080 ERASE LT$,LF,LB : GOSUB 1520 : RETURN
    2090 ' ::: the command is: QUIT
    2100 GOSUB 2120 : IF Q THEN SYSTEM ELSE RETURN
    2110 ' ::: if the file has been changed, get confirmation
    2120 IF NOT FMOD THEN Q=TRUE : RETURN
    2130 PRINT : PRINT "The file has been MODIFIED...!"
    2140 INPUT "...are you SURE you want to do this (Y/N> ";CIN$
    2150 CIN$=LEFT$(CIN$,1)
    2160 Q=(CIN$="y") OR (CIN$="Y") : RETURN
    2170 ' ::: get a filespec for load or save
    2180 PRINT : PRINT "Give me a filespec";
    2190 IF FSPEC$<>"" THEN PRINT " (";FSPEC$;")";
    2200 INPUT CIN$ : IF (CIN$+FSPEC$)="" THEN PRINT : GOTO 2180
    2210 IF CIN$<>"" THEN FSPEC$=CIN$
    2220 RETURN
    2230 ' ::: find the top(A) and bottom(Z) lines of data
    2240 A=LCUR : WHILE LB(A) : A=LB(A) : WEND
    2250 Z=LCUR : WHILE LF(Z) : Z=LF(Z) : WEND
    2260 '..minus trailing, empty lines, if any
    2270 WHILE LT$(Z)="" AND Z<>A : Z=LB(Z) : WEND
    2280 RETURN
