Results 1 to 5 of 5
Thread: Mac Performa 575 Screw Size and Type
    Nov 2017
    Los Angeles
    13
    Default Mac Performa 575 Screw Size and Type
    Does anyone know the screw size and type for the rear cover of a Macintosh Performa 575?
    Thanks,
    Don
    Apr 2015
    Austin, Texas
    1,917
    If the thread pitch is fine, I think it uses M4 screws. If the thread is larger, it should be the standard #6-32 screws.
    Nov 2017
    Los Angeles
    13
    Thank you for the data!
    Don
    Nov 2017
    Los Angeles
    13
    In case anyone needs the data, after much research and trial and error I have determined that the screw size and type for a Mac Performa is M3-0.5, 6mm long, truss head.
    I have not verified the original screw drive type. It is either Phillips or Torx.
    Don
    Apr 2015
    Austin, Texas
    1,917
    So it looks like it uses standard PC case screws, just a bit longer.
