Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Easy to set up Network System that work with Boot ROMs?
    Dec 2012
    Koo-Wee-Rup, Victoria, Australia
    27
    Default Easy to set up Network System that work with Boot ROMs?
    I picked up a very rare network card for an IBM JX which is looking for a network to serve it a file. On boot, it seems to be waiting for a response from a server but eventually times out. Appears to be coaxial Ethernet - is there something simple I can install that supports an NE2000 so I can see if I can serve it a boot image?
    Thanks for any thoughts;
    Anthony
    You should be really careful unless you know exactly what that card is. The IBM Cluster Adapter was period correct for the time, and it also uses a BNC connector. And it's also a totally different network technology that is not compatible with Ethernet.
    Can you post higher resolution pictures of the card? (Both sides ...)
    Dec 2012
    27
    Hi Mike -
    Sure thing - here it is.
    For more clues - I should point out it is one of the PCs mentioned in this press release -
    http://www.thepcmuseum.com/ibmjx/jx_in_bendigo.pdf
    Dec 2012
    27
    I am just reading this -
    http://minuszerodegrees.net/oa/OA%20...%20Adapter.pdf
    and I am pretty sure you are right - it will be an IBM Cluster Adaptor. Now I need to figure out what to do with it.
    Anthony
    That is what I expected. And it's good think you did not try to hook it up to Ethernet ... I'm not sure which side would earn the "hit points."
    I have two ISA versions of that adapter here and several PCjr versions of it. The technical reference is readily available. I am looking to port mTCP to it so that we can have mTCP running on top of native, IBM specific hardware, and for Internet connectivity I'll write a small gateway program to bridge Cluster to Ethernet. But I haven't even started poking at the adapter to make it send or receive a packet yet. Compared to Ethernet the programming model it's quite icky; it is like the love child of peer-to-peer SNA and Ethernet.
    Keep it safe - it will make a wonderful part of a VCF exhibit one day. (The PC, PCjr, and PC XT all part of an IBM Cluster Network.)
    Dec 2012
    27
    I have just bought a New Old Stock IBM PC Cluster Adaptor. Is the software available somewhere? Would love to give it a spin. Would be great to bring a JX over to the USA as part of a PCjr exhibit.
    I ordered a JRide the other day - over the next week or two I plan to wire up an Adaptor to theoretically use PCJr sidecars in the JX expansion bay.
    Feb 2017
    Guildford, U.K.
    418
    It seems to have been a predecessor to the IBM PC Network (Broadband) cards (CSMA/CA vs CSMA/CD and 375Kbps vs 2Mbps). Maybe there is some IBM Networking software, but I'm not sure which would cater to interfaces that old.
    https://en.wikipedia.org/wiki/IBM_PC_Network
    Mirror of the old IBM PCCBBS here:
    http://ps-2.kev009.com/pccbbs/
    The allfiles.txt in the root has all the descriptions.
    Dec 2012
    27
    I have just found this article from 1989 which indicates that IBM JX computers with cluster cards can communicate with an AT with a cluster card under Novell Netware. This is apparently also an option.
    https://iubmb.onlinelibrary.wiley.co...2889%2990008-3
    I need to see if I can find a copy of this version - it may contain drivers for this board.
    Anthony
  9. #9
    Feb 2017
    Guildford, U.K.
    418
    A possible clue to the Netware support for the IBM Cluster Adapter variants:
    https://www-01.ibm.com/common/ssi/cg...h_a&subtype=CA
  10. #10
    Mar 2011
    Atlanta, GA, USA
    1,593
    Quote Originally Posted by Anthony Beckett View Post
    ...for an IBM JX...
    Oh sure.. you just have to rub in the fact you have a working JX that isn't smashed into a million plastic bits like mine!
    "Good engineers keep thick authoritative books on their shelf. Not for their own reference, but to throw at people who ask stupid questions; hoping a small fragment of knowledge will osmotically transfer with each cranial impact." - Me
