Results 1 to 4 of 4
Thread: Micro House Technical Library cd
    Default Micro House Technical Library cd
    Does anyone know were I can get the full version of the Micro House Technical Library cd, not the demo or book. the cd and extra libs that later became the th99?
    thanks.
    Jan 2014
    Western North Carolina, USA
    1,333
    Actually, yes. I have one. May not do much good, though, since a specific version of the install floppy is required, and I haven't located that yet, nor have I located the NetSentinel hardware key; this was in a whole box of CD's from a computer reseller, and there are some other goodies in that box that I really need to go through, like old Seagate Backup programs, Cheyenne backup, Compaq CD's, WIN95 A&B CABs, and others; I have a whole box of miscellaneous hardware from that reseller, and the NetSentinel key might possibly be in there somewhere. Here's the contents of the 'version.197' file on the CD:
    旼컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴
      VERSION.197
              납
      Quarter켸읕훊ear
    읕컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴컴
    This is the 1st quarter 1997 version of the MTL on
    CD-ROM.
    This CD-ROM must be installed from the 4th quarter 1996
    installation floppy disk.  Installation floppy disks from
    previous quarters are not compatible with this CD-ROM.
    Micro House International +1 800-926-8299
                              +1 303-443-3388
        Description of directories and files on this CD
    Directories marked with a * contain files that are only
    accessible by the MTL engine and are of no use to you.
    Directories marked with a + contain files that may be
    useful to you.
    \C                 * Hard drive controller card documents.
    \DRIVERS           * Software and drivers.
    \DRIVERS\HP        + HP LJ4 Printer Drivers.
                         If you are having trouble printing from
                         the MTL to your HP LJ4 printer specify
                         this directory as the "diskette provided
                         by the manufacturer" in Windows printer
                         setup.
    \DRIVERS\NETWARE   + The latest DOS/Windows Netware Drivers.
    \FCCID             + FCC ID Look Up.
    \INDEXES           * Databases and indexes used by the MTL.
    PLEASE SEE THE HELP TOPIC "USING THE KEY" IN THE MTL HELP FILE
    FOR DETAILED INFORMATION. PRESS F1 WHILE IN THE MTL FOR HELP.
    CALL MICRO HOUSE PRODUCT SUPPORT IF YOU CAN NOT GET THE KEY
    TO WORK AT 303-443-3389.
    \KEY               + NetSentinel(tm) Protection key utilities.
                         If you have a BEIGE key or a NETWORK
                         version then use these utilities.
     DOS      TXT      + How to use the key with DOS (or Windows)
                         and IPX or NETBIOS
     DOSMON   EXE      + Network monitor program for use with DOS
                         and IPX or NETBIOS
     DOSMON   TXT      + How to use the network monitor with DOS
                         and IPX or NETBIOS
     FINDKEY  EXE      + Utility to see if the key can be found.
                         For Micro House Product Support use.
     IXSTAT3  EXE      + Utility that returns IPX/SPX information.
     NETW311  TXT      + How to use the Netware Key NLM
     NMONDI   EXE      + IPX/SPX monitor for DOS.
     NMONDN   EXE      + NetBIOS monitor for DOS.
     NMONOM   EXE      + Multi-protocol monitor for OS/2.
                         See OS2MON.TXT
     NSRVDI   EXE      + The Netware Key EXE (for 2.15, 2.2, 3.1x, or 4.x servers)
                         If you want to run the key from a workstation then
                         attach the key to any workstation and load this
                         program on that workstation.  Other users will then
                         be able to find the key on the workstation.
                         If you use this method then DO NOT load the
                         NSRVNI.NLM.  See NSRVNI.NLM below for more information.
     NSRVDN   EXE      + The Windows for Workgroups (or ANY NetBIOS compatible
                         network) Key EXE.
                         Attach the key to any workstation and load this
                         Do not use this for Netware.  Instead use
                         NSRVDI.EXE or NSRVDI.NLM.  Also see NSRVGX.EXE
     NSRVDN   PIF      + A Windows Program Information File for NSRVDN.EXE
                         Run this to launch NSRVDN.EXE
     NSRVGX   EXE      + The Windows NT and Windows 95 Key EXE.
     NSRVNI   NLM      + The Netware Key NLM (for 3.1x or 4.x servers)
                         If you want to run the key from the server then
                         attach the key to the server and load this NLM.
                         MTL users will then be able to find the key on
                         the server.
                         NSRVNI.EXE.  See NSRVNI.EXE above for more
                         information.
     NSRVOM   EXE      + The OS/2 Key EXE for use with NetBIOS and Named Pipes.
                         See OS2.TXT for more information.
     NWIPXSPX DLL      + In order for the MTL to find the hardware key
                         when it is attached to a Novell File Server,
                         the NWIPXSPX.DLL file must be in the default
                         Windows or Windows System directory.  Use the
                         NWIPXSPX.DLL file that is in the \KEY directory
                         if there is not one in the Windows or System
                         directories already.
     OS2      TXT      + How to use the key with OS/2
     OS2MON   EXE      + The network monitor for use with OS/2
     OS2MON   TXT      + How to use the network monitor with OS/2
     OS2SNTNL SYS      + OS/2 key driver.  See OS2.TXT
     README   TXT      + Additional information on the key files.
     RHPANELP DLL      + Used by the NMONOM.EXE OS/2 program.
                         See OS2MON.TXT
    \KEY\SYSDRVR       + Port Drivers for Sentinel(tm) Protection key.
                         These port drivers allow better communication
                         with the printer port thereby allowing the key
                         to work better.
    \M                 * Main Board documents.
    \N                 * NIC documents.
    \NC                + NetCom(tm) NetCruiser(tm) trial version.
                         Internet connection package.  Includes
                         free conect time. Run SETUP.EXE.
    \REG               * Electronic Product Registration files.
    \SYSFILES          * Miscellaneous files used by the MTL.
    \UTILS             + Miscellaneous Micro House utilities.
     COMPRESS EXE      * Use only at the advice of Micro House
                         Product Support.
     DRIVEPRO 1        + Database file used by MHSETUP.EXE
     DRIVEPRO 2        + Database file used by MHSETUP.EXE
     DRIVEPRO 3        + Database file used by MHSETUP.EXE
     DRIVEPRO 4        + Database file used by MHSETUP.EXE
     DRIVEPRO 7        + Database file used by MHSETUP.EXE
     DRIVEPRO 8        + Database file used by MHSETUP.EXE
     ESCAN    EXE      + Scans an IPX network for Ethernet cards.
     FLAG     BAT      + Turns your DOS prompt into an American flag.
     IDECACHE EXE      + Turns on/off IDE look-ahead cache.
     MHESDI   EXE      + Returns information on ESDI drives.
     MHIDE    EXE      + Returns information on IDE drives.
     MHRESTR  EXE      + Restores information saved with MHSAVE.EXE
     MHSAVE   EXE      + Saves vital system information to a file for later use.
     MHSETUP  EXE      + Simple CMOS setup utility.
     MHSYS    EXE      + DOS Sys replacement.
     README   TXT      + A description of MHSETUP.EXE
     UNCOMP   EXE      * Use only at the advice of Micro House
                         Product Support.
    \V                 * Miscellaneous I/O card documents.
    ### END OF FILE ###
    쿎opyright(c) 1997, Micro House International with
    쿪ll world rights reserved.
    This is what it looks like:
    thanks. Maybe some day I can find a hard copy to buy.
