Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
Thread: microPDP-11 Rebuild (Saved from going to the trash!)
    May 2020
    St. Albert, AB
    12
    Default microPDP-11 Rebuild (Saved from going to the trash!)
    Howdy all,
    I managed to come into possession of a lot of PDP hardware, including most of a entire rackmount PDP-11/44, tons of spares, a microPDP-11, and various VAXstations with accessories.
    I am starting the restoration work with the microPDP-11, as it has the easiest learning curve to get to understand it, since it was available up until 1990!
    This thread will track the progress. The computer was in excellent condition, and I believe it was still used until some minor failure. I work as an electronic specialist at a local laser gas detector company, so I have access to many interesting resources to assist in my projects, so pretty much no advice will go unheeded... if I need to build an interface board, so be it; if I need to build a cable, so be it, if I need to solder a bunch of components and/or test others, so be it.
    Currently I have physically cleaned it up and have powered it on. I have a virtual terminal device that connects to the D0 output that takes a PS/2 keyboard and VGA output, but it currently cannot seem to talk to the terminal at 9600 baud, 8+1, no parity (it matches the rear console settings). As I left it running, it started to smell exciting, so I have powered it down and will begin rebuilding the power supply to spec. Currently the front lights are green for RUN. I will attach some photos to the next post.
    I hope my adventure will be interesting to some of you. I have never worked on "mainframe" systems before, but I have plenty of experience with 8086 systems and upwards. I have been watching a lot of interfacing videos and restoration of big mainframes, so I understand the theory of how they operate deI also work as an electronic specialist at a local laser gas detector company, so I have access to many interesting resources to assist in my projects. ^_^
    Nice
    6,037
    44
    Welcome to the forums and nice haul by the sounds of it.
    Thankfully the PDP-11 series was not mainframe class, just minicomputers.
    A lit RUN light is good for the most part because that means nothing immediately caused the CPU to halt like bad ram or ROM. The lack of a console might come down to just cabling.
    = Excellent space heater
    Feb 2011
    Salisbury Maryland
    822
    Not that famiyure with the 44 but spent a lot of time with its ancestor the 34, welcome to the world of Unibus! Down load the 11/44 manual and look at the card layout in the system. You have to have active cards or grant cards in every slot or else the system hangs. Sometimes when they pull this stuff out of service they yank cards and leave open slots and on Unibus that’s a issue.
    Would assume the system once working will give a boot prompt and by escaping that you can bump back into ODT that will allow you to look at and poke addresses in the system and do things like load loop programs and the like for testing.
    What type of storage drives were with it?
    May 2020
    St. Albert, AB
    12
    Sorry for the delay in replying everyone, I had to wait for the thread to get approved and then it took some time for me to get notification that it did.
    I currently took apart the main power supply for a full rebuild, I will document that in a video and video hopefully sometime this week.
    I managed to get quite a lot of PDP-11 stuff- lots of unibus cards for the rack mount version. I also have lots of full devices including TU80, bunch of RS02s, some HDD arrays (mostly MFM but some SCSI), a big 10?" platter drive, three RL01s, tons of other goodies that I have yet to figure out what they are. I also got a bunch of VAX systems and related networking supplies for them.
    I am planning on selling some of it as a reasonable cost to finance the restoration of a select few of these parts.
    May 2020
    St. Albert, AB
    12
    Okies, I figured out how to post photos to the thread. Here are some of the things I managed to pick up- there are more items but I need to dig them all out. image001.jpgimage002.jpgimage003.jpgimage004.jpgimage005.jpgimage006.jpgimage007.jpgimage008.jpgimage009.jpgimage010.jpgimage011.jpgimage012.jpgimage013.jpgimage014.jpgimage015.jpg
    May 2020
    St. Albert, AB
    12
    I posed the photos but it is pending moderation. Will check back later.
    May 2020
    St. Albert, AB
    12
    I still haven't had any of my posts approved, so it might be a while until you see this reply.
    I finished rebuilding the power supply, so it no longer smells like burning death when the computer is running. I will post pictures once I learn how to do that.
    Right now I am trying to get the terminal to communicate but I think I need to arrange the cards for the computer to boot.
    May 2020
    St. Albert, AB
    12
    Well it seems that none of my posts are approving, I will just end up doing this over Youtube I think.
    May 2020
    St. Albert, AB
    12
    Oh! It seems my posts are getting through. I will post more photos now:
    This is a before and after rebuild of the power supply:
    Works great without any smells now!
    But having issues with the cards, played around with them and now I cannot get the RUN light to start up now. Looking into it more. I think I have enough cards for a minimum config...
