Results 1 to 8 of 8
Thread: My ultimate IBM 5150
    Cool My ultimate IBM 5150
    Here is my fairly tricked-out IBM PC 5150 that I've had for quite a few years now. I think I got it in 2013.
    The configuration has changed a lot over the time I have had it, but I think I've finally settled on something I'm 100% satisfied with.
    When I got it, it had an Intel Inboard/PC 386 accelerator board, two very cheap and poorly-built half-height floppy drives and a dead Seagate ST-250R RLL hard drive paired a Seagate ST-11R controller.
    First thing I did was put a different hard drive in, which was a Seagate ST-238R. This drive proved unreliable, so I swapped that for a Seagate ST-277R, which is very healthy and sounds smooth as butter.
    A few years after that, I found an original IBM-branded Tandon drive at Goodwill (which was very unexpected), so the half-height drives went out and the Tandon went in.
    A month or so ago, I decided to build this into my perfect 5150. The accelerator had to go. I want this to run like a true 5150, not an AT clone. I installed an NEC V20 CPU instead. I will keep the Inboard/PC for now. It's safely tucked away in an anti-static bag.
    After that, I installed an AST SixPackPlus, with 384KB, so I have full 640KB.
    Next I installed a BOCA EMS board I found for a great price on eBay (pictured below). It has 1MB installed, and can be upgraded to 2MB, which I'll do someday. Great for things like Windows 2.xx.
    Last thing I installed just a few days ago is a second hard drive. It's a Seagate ST-251-1 42MB MFM drive, formatted to 65MB RLL, essentially making it another ST-277R. Oddly, this drive used to be dead, until I removed to cover, put it back on, and now it works! Doesn't even have a single bad sector! It sounds insane with two of the monsters. Love it.
    This PC was built in July of 1985, so it's my oldest IBM PC.
    This PC has served me very well over the years. Will definitely never get rid of it.
    And for anyone wondering, yes the PSU has been upgraded to a 200-watt unit. And yes, all of my expansion slots are full, but there's really nothing else I want to put in it, so it doesn't matter to me.
    That's my PC!
    Compaq - “It simply works better”
    Quote Originally Posted by compaqportableplus View Post
    ... And yes, all of my expansion slots are full, but there's really nothing else I want to put in it, so it doesn't matter to me.
    What cards do you use? Just curiosity.
    www.baltissen.org
    For this 5150, a Hercules compatible display adapter, AST SixPackPlus, BOCARAM EMS board, floppy drive controller and a Seagate ST-11R RLL controller.
    Sep 2016
    Shrewsbury, MA
    1,289
    Nicely done! I can appreciate the approach with the Hercules card and stuff. I've got a 5150 set up very similarly although with less ram, but I'm trying to go a little more ridiculous with my 5160, I'm currently looking for a 5154, inboard 386, and 5161 for it.
    Thanks! The EGA 5154 monitor is the next IBM accessory I’d like to get. Those are killer. I’d like a 5161 at some point as well.
    I like to have a least one set-up with monochrome and one with color, as I like both. And since I have CGA with a 5153 on my primary 5160, I leave this 5150 with Hercules. Windows looks lovely in high-res green.
    Sep 2016
    Shrewsbury, MA
    1,289
    My setup is very similar- my 5150 has hercules on a 5151 and my 5160 is running a 5153 although I did get an ATI EGA Wonder which is a pretty neat card. Any video mode on any monitor essentially, so I can run ega games just fine, although Windows doesn't get along with it as well... If you ever want to let go of that Inboard/PC keep me in mind! My goal with my 5160 is to put one of those in with one of those TI/Cyrix 486dlc chips and just go all out on it
    Mar 2020
    Stouffville, Ontario, Canada
    49
    That's a beautiful machine. Well done getting it back to it's roots.....with some improvements.
    Sounds cool! Yes, I’ll definitely keep you in mind if I decide to part with it.
    Quote Originally Posted by AndyM1981 View Post
    Thanks!
