Results 1 to 10 of 19
Thread: IIGS Astec AA13581 repaired 2 months ago went bust. Need help
    Jan 2012
    Connecticut, USA
    2,839
    Default IIGS Astec AA13581 repaired 2 months ago went bust. Need help
    I had an Apple IIgs psu model Astec AA13581 psu that was in really sad shape a couple months back. Dirty and probably saw some water damage. I replaced all the Electrolytics and AC safety caps and it has worked great for 2 months until last night. IT started giving intermittent issues that presented like power switch problems (it would turn on and off for a split second by rocking the switch.. Then dead.) I tried a brand new switch as that is what it seemed but the first switch was fine and the new switch made no change.
    I am getting NO voltages out of this thing on any of the pins. Could use some help checking the obvious. Anyone have a schematic or guide on this type? Oh yeah, fuse is fine.
    May 2018
    Lancashire
    455
    10
    While it was an Apple II psu, I had a very similar problem which was due to a cracked solder joint on the big power transistor and it would refuse to start. Might be worth a quick trip around the board ?
    Current fleet
    TRS80 Model 4 - BBC B - Tatung Einstein - PCW9512 - PET 3032 - C64 - ZX81 - Spectrum 48K - Amiga A500 - VAX 3100,3300,4000VLC & 4000 Model 96 - Apple II europlus - Apple iMAC G3. Sharp MZ-80K. - DEC Micro PDP 11/73 - IBM 5160 XT - Multibus 286/10.
    Jan 2012
    Connecticut, USA
    2,839
    Quote Originally Posted by Gary C View Post
    I was in the same mindset. I was checking for bad joints and nothing obvious jumped out at me.
    Jan 2012
    Connecticut, USA
    2,839
    Are there any Sam computer facts or anything that late in the game for troubleshooting these psus? Anyone have a schematic?
    Dec 2012
    Colorado
    221
    If it isn't blowing the fuse, then maybe it is shutting down due to an overvoltage or overcurrent regulation. Does it shutdown if you don't have any cards in the slots? Do you have an oscilloscope with a differential probe?
    Dec 2012
    Colorado
    221
    Found this Apple document for older switched power supplies, it has good information about switched mode power supply circuits, but won't answer your questions directly. http://bitsavers.org/pdf/apple/power...lies_Aug82.pdf
    Jan 2012
    Connecticut, USA
    2,839
    Quote Originally Posted by cruff View Post
    you can test the voltages when the psu is out of the system on its own. I have an identical psu (exact same pcb) I tested this with. You get two gorund pins, a 5v a 12v a -5v and a -12v. With this psu you get nada.
    Dec 2012
    Colorado
    221
    That makes it easier for testing at least you don't have to put a load on it to behave. Unfortunately in my IIgs I have a power supply made by DynaComp, so I can't go about looking to reverse engineer it to get you the information you'll probably need. Did you reheat the solder joints for the parts you replaced, just in case one of those went open?
    http://www.appleiioz.com/appleiioz/A...t_Diagram.html
    Maybe? No, this one...
    The Lower Planes BBS Ports 22/23 telnet or SSH
    Pineapple Home of the Hardware Database
    Australian BBS list old style BBS registry listing.
    Sep 2016
    641
    Since it has been recapped already, your problem is most likely the little feedback transformer. One of the windings goes open circuit, I see it mostly in 2+ and 2e power supplies.
    The quick way to check is is measure the resistance across R7 (56R), if you read 56 ohms or close to it then the winding has gone open.
    You can replace it with one from a donor supply or do what I do and wind about 30-35 new turns of enameled copper over the top of the old winding.
