May 30th, 2020, 06:24 PM
#1
5153 convergence and sharpness
I've seen some sharp CGA images on these forums now and again while my 5153 doesn't look so good. I've tried adjusting the convergence and screen focus as best as I can, but I can see they need more work.
Are there any other issues that might affect sharpness that should be corrected first?
The image is a bit narrow as well, another challenge to to tackle. I'm certain the PS voltage is correct because I replaced the original 120V item with a modern open frame industrial unit so I could use the monitor on 230 VAC.
Tags for this Thread
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
