Results 1 to 8 of 8
Thread: Paradise PVGA1A-JK isa 8 bits
    Default Paradise PVGA1A-JK isa 8 bits
    Hello there !
    I try to fine tune my 80286-12 + 2 mb + 80287XL + hdd 40 mb + fd 5,25 p + fd 3.5 p + 3C509B...
    Everything ok under dos 6.22. Even networking with mtcp !
    Now I am at Windows 3.1 stage !
    The video board (a 8 bits isa Paradise PVGA1A-JK chip + 8 x 4464 memory chips) works well in VGA mode and in Super VGA 800x600x16 mode (with standard Microsoft drivers coming with Windows 3.1).
    So I think it should also work in Super VGA 640x480x256 mode but... no ! With this driver (again coming with Windows 3.1) system hang at Windows startup...
    I dont think I made something wrong... but this look strange to me !
    Googling around that show that a Paradise driver should do the job but everything I have found under the name Paradise or WD and test dont work...
    So again I hope an explanation and may be a link to suitable windows 3.x driver for this board....
    Thank you very much. Regards.
    Philippe
    Sep 2012
    Indiana, USA
    521
    Yes !
    Choice is not easy. If have test two coming from this page and both fail in 640x480x256 and in 800x600x16.
    Aug 2015
    Kansas City area, US
    66
    I _think_ you need 512k of ram for 640x480x256.
    Right. I have this same card. The RAM chips are 41464 chips = 64Kx4. So only 256K on the card.
    There should be a VGA driver for 640x400x256 (400 lines, not 480), which fits into 256kb.
    Since you have an AT system, why not upgrade to a 16-bit VGA card?
    "Will the Highways on the internets become more few?"
    V'Ger XT
    Hello,
    You are right : basic calculations show that 640x480x256 colors don't fit in the memory board (256 kB) but that 800x600x16 colors is ok...
    And I pay not sufficient attention to the 400 - 480 lines detail.
    Thank you for all your replies.
    Regards.
    Philippe
    PS yes I think to change this board but this one look and have a 'speed' from last century so...
    Your VGA card doesn't support 640x480 (256 colors) with 256KB VRAM.
    It needs over 300KB of VRAM.
    So you should increase VRAM.
