Results 1 to 10 of 20
Thread: Optimal Instruction Set for Homebrew Computer?
    Sep 2011
    Michigan, USA
    188
    Default Optimal Instruction Set for Homebrew Computer?
    Hi, I have built a homebrew computer using TTL IC's according to the architecture described by Eckert in his paper "Microprogrammed Versus Hardwired Control Units: How Computers Really Work". The architecture is shown in the attached diagram. It is a fairly basic machine with a 12 bit bus consisting of 8 data bits and 4 control bits. I built a hardwired controller for my first pass, and am in the process of doing some testing. To do the testing I am hand coding to create hex files that go into a 'ROM A' and 'ROM B'
    The computer has 8 possible instructions. They are:
    Symbol, Hex Value, Description
    LDA* 1 Load Accumulator with data from the address given
    STA* 2 Store Accumulator data at the address given
    ADD 3 Add B to the Accumulator, store in Accumulutor
    SUB 4 Subtract B from the Accumulator, store in Accumulator
    MBA 5 Copy Accumulator to B
    JMP* 6 Jump to new program count (Program counter modified)
    JN* 7 Jump if negative flag is set. (Program counter modified)
    HLT 8-F Halt by stopping clock. (Not currently functional)
    ‘Fetch’ N/A Clock ticks 0, 1 and 2 always load the next instruction
    *Any command with an asterik requires a ‘ROM A’ address or program count value in the first 8 bits.
    So, basically I am at the starting point of creating a working language from these commands. Before I proceed with that I started wondering if these 8 instructions are the best choice from a practical point of view. It would be easy enough for me to substitute or change an instruction at this point... so I am wondering if anyone has some thoughts about this? Probably my biggest concern is the conditional jump is based on the negative flag being set.
    More information about the project is here
    http://www.mtmscientific.com/stack.html
    Michael
    Sep 2006
    Silicon Valley
    2,293
    Quote Originally Posted by mmruzek View Post
    - subroutines
    - memory indexed addressing
    the pdp-8 had the notion of auto-indexed memory locations, which you could use to implement index or stack registers in memory
    it doesn't appear there is any mechanism to change microcode flow conditionally
    you could also make greater use of the ALU operations in the F181 if you had an instruction that exported the ALU control bits
    34,597
    I assume that you've seen this OIC article.
    Having programmed very CISCy and RISC mainframes, when everything is said and done, I don't see a lot of difference. I do see that your ISA lacks logical operations, although left-shifts are possible with the ADD instruction.
    Sep 2006
    Silicon Valley
    2,293
    Everything boils down to storage latency and clockrate.
    34,597
    Yeah, pretty much--and word size.
    Carry functions or increment. You can get rid of either add or subtract but you do need a bit wise complement.
    Addition and subtraction are equivalent - one is sufficient.
    All logical operations can be synthesized from NAND or NOR, so you want either one.
    For subroutine support, you need to be able to store and recall the program counter.
    34,597
    I'm assuming twos-complement, but bitwise complement is obtained by subtracting from all 1's. e.g. FFFF-AAAA = 5555, FFFF-0000 = FFFF, etc.
    Sep 2006
    Silicon Valley
    2,293
    Jun 2014
    Salt Lake City, Utah
    550
    Hi Michael,
    Take a look at this, really nice ttl computer. I boght a kit and it is first class.
    https://gigatron.io
    P.s. Love all the projects on your site.
    Len
    Spread the joy of Vintage Addiction
    -->www.chronworks.com/<--->www.i8008.net/<--
