Results 1 to 6 of 6
Thread: disk test utility for CP/M 80?
    Default disk test utility for CP/M 80?
    Hi everyone,
    Wondering if there is a CP/M program that tests disks?
    Ideally, something that is configurable for # of tracks, # of sectors, and sector size.
    Any suggestions?
    thanks!
    Mar 2013
    Chaffee, MO
    1,487
    Disk Utility (DU-87.COM, .ASm, .DOC) for CP/M does, but it automatically configures itself from the
    Information found on the inserted Floppy. You could likely modify the .ASM for your specific needs.
    Larry
    Arrow
    Quote Originally Posted by ldkraemer View Post
    Larry
    Thanks i will look for it . Cheers!
    Hey I tried.. no luck. Do you have a link? Thanks again
    Perhaps DU-V77 found in SIG/M Volume 44 ?
    http://www.classiccmp.org/cpmarchive...ols000/vol044/
    May 2009
    Connecticut
    4,744
    A competing disk utility can be found at http://www.cpm.z80.de/binary.html#utilities
    DU is a good program thanks.
    I was also hoping to find a speed tester or benchmarking program for disks. It may be a long shot since to measure speed you need time, and that might not be a common CP/M function. But, is there a speed testing utility that anyone knows of?
    thanks
