Results 1 to 10 of 13
Thread: Very old and huge floppy dirver
    Default Very old and huge floppy dirver
    Hello. I am new here. You have a really nice Forum!
    I have found this huge floppy disk drive. Is huge and very heavy. I send you some pictures.
    I have looked up in the internet but I have couldnīt find anything. Do you have any idea of the name,model or year?
    Sorry if I post in the wrong forum, I have tought it was the right one
    Thank you.
    Kind regards
    Oct 2016
    166
    Looks like a single full height 5.25" floppy drive in a portable (lugable) carry case and for a Bosch (German company) computer of some sort. It also appears to need TLC with the power cord cut off and may very well be for 220/240VAC if made for Europe.
    4,744
    It may be a complete computer. It looks to have only a small serial port in addition to the power cord which would fit with a system designed to work with a terminal or specialized hardware. I would expect an external floppy drive to have a connector with 30 to 50 pins or some other high speed interface.
    Open it up and there should be a complete board or boards under the drive bays.
    Sorry, I duplicate the post.
    Tomorrow Iīm going to open and take pictures, but I think is for 3,5"
    The heat sink on the back is more that would be used for a single drive by itself. There is likely some kind of computer inside. It may be intended as a reference drive for special purposes, wih the lock on the front to keep it from getting contaminated or such.
    May 2018
    Lancashire
    518
    14
    Is that red thing on the front a cap over another connector for a video terminal or a big button.
    It sort of reminds me of a PLC programming unit that you took out on plant to reload systems.
    Current fleet
    TRS80 Model 4 - BBC B - Tatung Einstein - PCW9512 - PET 3032 - C64 - ZX81 - Spectrum 48K - Amiga A500 - VAX 3100,3300,4000VLC & 4000 Model 96 - Apple II europlus - Apple iMAC G3. Sharp MZ-80K. - DEC Micro PDP 11/73 - IBM 5160 XT - Multibus 286/10.
    May 2018
    Lancashire
    518
    14
    same unit for sale here
    https://translate.google.com/transla...search&pto=aue
    States its part of an engine tester.
    Looks like a SBC on top with a drive controller at the bottom with a PSU on the back.
    Haven't found any reference on the bosch sites, the old kit has a similar style of boxes.
    The PDR100 is a printer but main unit even has the same big power button.
    Current fleet
    How about a picture of the board on top?
    One wonders if maybe it is a print buffer.
    It is part of an automotive testsystem, in German 'Motortester' aka an engine test system.
