Page 3 of 8 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 71
Thread: Is it possible to set A: to boot automatically on an xt-ide?
  1. #21
    May 2011
    Outer Mongolia
    2,546
    Quote Originally Posted by Malc View Post
    I had to have a look and found it in a drawer, You're right there is indeed 5V on pin 20, My adapter is r2b, Dunno what i was thinking there, I must get some sleep 2 am here
    Eh, no worries. I'm trashed enough myself after several days of not enough sleep I'm having trouble rotating the IDE pinout in my head to figure out what that 5v line would have shorted to if the cable went in backwards, because that's almost certainly the source of the smoke.
  2. #22
    Nov 2009
    Dublin, Ireland
    1,254
    When you say it wouldn't boot, Do you mean the computer would not start
    Wouldn't POST and no flashing cursor on monitor which usually appears after a few seconds
  3. #23
    Nov 2009
    Dublin, Ireland
    1,254
    Well with just the xt-ide card in the pc with no CF adapter. PC doesn't Post. Also the xt-ide pins and collar show signs of burning. I'll have to test the the 5150 slot nearest the power supply to see if that's been damaged.
  4. #24
    Nov 2009
    Dublin, Ireland
    1,254
    I've tested the CF card in my PS/1 and it works.. There should have been two partitions on it with data, however the second partition was not accessible until I reformatted it.. I'll test the ide to CF adapter next. Have to move the monitor to open the case. Had forgotten how heavy CRTs were.
  5. #25
    Nov 2009
    Dublin, Ireland
    1,254
    on the 5150 the four wire power supply cable, the red wire looks damaged.
  6. #26
    Nov 2009
    Dublin, Ireland
    1,254
    The setup was a lo-tech xt-ide Rev 2 plus an IDE to CF adapter.
  7. #27
    Nov 2009
    Dublin, Ireland
    1,254
    I have a mouse systems card in the slot where i had the xt-ide and the 5150 boots up
    EDIT: trying to load sysinfo.
  8. #28
    Nov 2009
    Dublin, Ireland
    1,254
    Sysinfo shows 2 serial ports. i presume 1 is the ast sixpak plus com and the mouse systems card is the other. so slot looks undamaged
  9. #29
    Nov 2009
    Dublin, Ireland
    1,254
    The cf to ide adapter works in the PS/1 so it looks like the xt-ide is damaged
  10. #30
    Nov 2009
    Dublin, Ireland
    1,254
    I'm saving up to buy the beatles singles box set or glitches rev4a xt-ide board.
