Results 1 to 10 of 18
Thread: Menu maker / batch file?
    Default Menu maker / batch file?
    Hi all,
    In Linux, this would be an easy task, but in DOS, not so simple for me (either because I may have forgotten how to do this sort of stuff, or because you can't do it with simple batch scripts).
    I have a text file, 5 columns: column 1 has a unique ID number, column 2 has the name of a BBS I want to connect to, column 3 has the telnet hostname for the BBS, column 4 has the appropriate port number. I also have a fifth column with notes which isn't of much consequence, but could be displayed if needed.
    The idea of the batch file is simple:
    1) Display the contents of each line of the text file.
    2) Ask for input for the user for the number of the unique ID related to the BBS I want to connect to
    3) Execute mtelnet <hostname> <portnum>
    I've looked at menu makers on google for a while as well, but couldn't find anything that would do what I need. If
    Thanks in advance
    Mar 2009
    Dublin, CA USA
    2,926
    I don't think you can do exactly that with a batch file, though others may correct me on this. I'd look to do it in basic with Quick Basic.
    34,613
    Not DOS batch, per se, but a good old add-on, called CENVID. Basically, interpreted C as a batch program. I used it a lot back in the day.
    Here's an example, HEXDUMP.BAT:
    @echo off
    REM **********************************************************************
    REM *** HexDump.bat - Hexidecimal dump of the contents of a file. This ***
    REM ***               examples program uses the CEnvi file routines.   ***
    cenvi %0.bat %1 %2
    GOTO CENVI_EXIT
    main(argc,argv)
       if ( 2 != argc ) {
          Instructions()
       } else if ( NULL == (fp = fopen(argv[1],"rb")) ) {
          printf("Could not open file \"%s\" for hex output.\a\n",argv[1])
       } else {
          dump(fp)
          fclose(fp)
    dump(file)
       Unprintables = "\a\b\t\r\n\032\033"
       for ( offset = 0; 0 < (count = fread(data,16,file)); offset += 16 ) {
          // display hex offset in file
          printf("%06X  ",offset)
          // display hex value for each number
          for ( i = 0; i < count; i++ )
             printf("%02X ",data[i])
          // fill in any extra gaps if count < 16
          while( i++ < 16 )
             printf("   ")
          // display ascii value for each printable character
          // substitute a period for unprintable characters
          data[count] = 0; // string must be null-terminated
          while( (UnprintableIndex = strcspn(data,Unprintables)) < count )
             data[UnprintableIndex] = '.';
          printf("   %s\n",data)
          if ( count < 16 )
             break
    :CENVI_EXIT
    4,744
    Might be able to do it with DOS 6's CHOICE command. Something like
    TYPE phonenum.txt
    CHOICE /C:1234 "ENTER NUMBER TO CALL"
    IF ERRORLEVEL 1 GOTO ONE
    :ONE
    metelnet <correct command line>
    GOTO END
    :END
    Each command line would need to be set up manually with this example and additional ERRORLEVEL branches for each line in the text file would be needed.
    Mar 2009
    Dublin, CA USA
    2,926
    TYPE phonenum.txt
    :ONE
    GOTO END
    :END
    This would not read and display the options from OP's text file and ask for a choice from the user. I am reasonably sure you could not do that in a batch file. So other tools would be needed, such as what Chuck suggests or writing it in a language of some sort (Basic, Pascal, C etc).
    34,613
    Also, if you're used to using bash or the bourne shell in Linux, there are ports to DOS.
    Aug 2009
    Oslo, Norway
    1,360
    3
    For number 1: why not simply TYPE the text file?
    Torfinn
    Mar 2009
    Dublin, CA USA
    2,926
    Quote Originally Posted by tingo View Post
    I think OP wants to use the text file as the menu items list and not re-create it in the batch file. So just typing it would display the contents, but then you'd have to build in a ton of if statements to accommodate the input Doing this could work, but it would double the work needed to add or remove anything.
    4,744
    The truly easy way would be if the program had its own macro language that accepted command line switches. Then one could
    TYPE the data file
    CHOICE the line to launch
    PROGRAM launch-macro errorlevel from choice which would start the program using the matching line
    Everything else would require some effort; either to build the conditional responses or to parse the data structure to create a command line.
    Mar 2009
    Dublin, CA USA
    2,926
    TYPE the data file
    How would this work is the data file contained more than 35 CHOICEs ?
