Results 1 to 10 of 19
Thread: Slot-mounted PS/2 Ports
    Jan 2019
    St. Paul, MN
    136
    Default Slot-mounted PS/2 Ports
    Prior to the ATX era, if you wanted a PS/2 port on an AT type machine, you used a mini-DIN port connector that fit in a card slot.
    There should be scads of these around in junk boxes. Does anyone have one? Classifieds isn't turning anything up, so I thought I'd ask the forum where they're most likely to be found..
    Thanks, Bill
    There are nearly one million feral cats just in the St. Paul / Minneapolis area alone.
    Sick & malnourished animals don't make for cute videos - Please spay & neuter your pets.
    Quote Originally Posted by WimWalther View Post
    Thanks, Bill
    Wow. I just got done picking up some AT cases and has one like that. It has a 4 wire/5pin connector
    34,941
    ...but the PS/2 mini-DIN are 6-pin, unless you're talking about the far end "Berg" connector.
    In any case, I have a couple, with brackets. One ends in an 8 pin dual-row connector; the other in a 10 pin connector.
    Did we lose some posts during the last hours? I read this topic earlier and at least two answers are gone. Same for another thread.
    you'd think that but they have become notoriously uncommon in recent years
    I guess many people simply threw them away
    I mean the connector that plugs into motherboard. The ps/2 is normal, but rhe other end is a single file 5 pin with 4 wires
    Sep 2008
    SE MI
    4,908
    6
    I bought a PS/2 keyboard/mouse adapter recently but it is only works with standard PCI slots and not PCIe. I failed to take in consideration the particular mobo only has 'mini' PCI risers. (useful when installing W7 when you bump into USB 3.1 compatibility issues)
    Outer Mongolia
    2,791
    Quote Originally Posted by New2vtgpc View Post
    It's been 20 years and my memory might be faulty, but I don't think those dongles were ever really standardized and came with a multitude of different plug arrangements. One meant for some particular brand of motherboard probably won't fit a different brand.
    If you can find the manual for your particular motherboard it *may* well have the pinouts of the header in it, which would let you build one yourself.
    34,941
    Yup, I think that the 8 pin termination was for a Tyan motherboard; I don't recall what the 10 pin was for--maybe a P1 PCChips board?
    these were the two most common pinouts
    the one on the right was used by AOpen (and Asus I believe)
