Results 1 to 10 of 24
Thread: Model I Issues
    Default Model I Issues
    Greetings.
    After a move across country, two of my five Model I keyboards gave up the ghost. This first one, when turned on, comes up with a blank screen for about 5 seconds, then displays the first image. After a bit it displays the second image. Pretty weird. Your thoughts would be appreciated.
    Oh, although very similar, don't confuse this post with: http://www.vcfed.org/forum/showthrea...air-assistance
    - Don Mankin -
    TRS-80 Models I, 4, 4p, Coco 2, 100, 102. Tandy 1000 RLX. Osborne 1a.
    At
    ari 800, 520 STm. Commodore 64.
    Amiga 1000. TI-99/A. Sinclair ZX-81]
    Aug 2013
    Philadelphia,PA area
    148
    Quote Originally Posted by Fooser View Post
    The first pic looks like you have no HSYNC/VSYNC just like #6 in the other thread points to. The second pic looks like the normal garbage screen that happens when you boot with an EI and no floppy in Drive 0.
    Tom
    I tried tweaking the variable resistors an got this image.
    - Don Mankin -
    At
    Just for grins, I replaced IC's Z5, Z6, Z57 and transistor Q2 with spares I had laying around. Absolutely no difference.
    - Don Mankin -
    At
    Mar 2013
    Chaffee, MO
    1,606
    How about a close up photo of the monitor so we can see the characters across the rows and columns.
    To check the address lines, remove the DIP Shunt at position Z3 and power-up the system. If the screen fills with a pattern of
    “@9@9@9@9...”, then all the address lines A0 – A9 are good. The remaining address lines A10 – A15 can be checked for
    activity with a scope.
    Larry
    @9@9@9@9..., then all the address lines A0 A9 are good. The remaining address lines A10 A15 can be checked for
    Larry
    Larry to the rescue... thanks again!
    Here is a picture with the DIP removed. When turning it on, it will either come up with a blank screen, or the picture attached. It's a crap shoot.
    - Don Mankin -
    At
    Mar 2013
    Chaffee, MO
    1,606
    Don, If I zoom and squint at the Imagine I can see a partial filled in character and I can make out the @9.
    But, they are fuzzy and not the full characters of the character set. I'm thinking it is in the Character Generator
    or in the Row addressing for the Bit matrix that make up the character. Can you read the Character Generator,
    or do you have one to swap as a test?
    Larry
    Mar 2013
    Chaffee, MO
    1,606
    We should be seeing the following:
    Larry
    Larry
    I replaced the 8046673 with a 8046670 and had the same results.
    - Don Mankin -
    At
    Well we're back from being evacuated from the Almeda fire here in Oregon. We're very fortunate, the fire devastated the area... as close as the other side of the street, but our home is intact.
    Now I have time to play with my toys again! I think I've addressed all of the suggestions in this post and am out of ideas. Any further thoughts on the problem would be greatly appreciated.
    - Don Mankin -
    At
