Page 6 of 6 FirstFirst ... 23456
Results 51 to 53 of 53
Thread: The AT as a minicomputer/server
  1. #51
    From https://www.pcorner.com/list/DIAGS/B...P/BIOSSIG.DBA/:
    A-Quality Computer
    Advantage Computer
    CompuAdd
    Everex AT
    had a (Phoenix) BIOS containing this message in the 1988-1989 time frame...
  2. #52
    ...and then there's this from 1984:
    The IBM AT will be the first IBM microcomputer which is a truly multitasking, multi-user system, It is built around the Intel 80286 microprocesser
    with 16/24 bit architecture and uses the Xenix operating system.
    The IBM AT multiuser system is currently configured for a maximum of three work stations...
    https://digitalcommons.unomaha.edu/c...parpubarchives
    XENIX was a Microsoft product at that time.
  3. #53
    Jan 2014
    Western North Carolina, USA
    1,382
    And in the 1984 timeframe the best selling Xenix computer was made by Tandy. https://books.google.com/books?id=5C...page&q&f=false
    Xenix running on the 6MHz 68K in the TRS-80 16B would wipe the floor with a 6 MHz 286.
    But I digress; while I was an associate at a Kmart in Atlanta in the 1986-87 timeframe, the Kmart layaway PoS machine was an AT clone ( I want to say made by Fujitsu, but that memory could be faulty) and running Concurrent CP/M; I remember looking up the hotkey to switch virtual screens; one of the virtual screens had a command prompt.
    Hilarity insued.
    Thus spake Tandy Xenix System III version 3.2: "Bughlt: Sckmud Shut her down Scotty, she's sucking mud again!"
