Results 1 to 6 of 6
Thread: Gateway 2000 won't get past BIOS screen
    Default Gateway 2000 won't get past BIOS screen
    Gateway 2000 P5-75 (Pentium 50mhz) with AMIBIOS
    This computer did work (and well) for me at one point but now it's not booting. It detects the Hard Disk (WDC AC2700H) ~700MB, however when it goes to boot from the HDD nothing happens.
    The BIOS screen shows:
    AMIBIOS (C)1992 American Megatrends, Inc.
    BIOS Version 1.00.10.AX1T
    049152 KB
    Please Wait...
    Keyboard....Detected
    Mouse.......Detected
    Hard Disk C: Installed WDC AC2700H
    Then nothing.. no failed to boot message or anything. Any ideas? Hard drive sounds like it spins up ok, no knocking/clicking, etc.
    34,927
    Will it boot from floppy? Could be a corrupted boot record on HD.
    Goo thought will give this a shot tomorrow. Have a favorite DOS boot/diagnostics disk?
    Welp I only had a few 3.5" floppies around here (I have tons of 5.25") - and apparently they're all bad because I can't write a boot disk. Ordered a few "new" ones, fingers crossed.
    2,133
    Quote Originally Posted by nullvalue View Post
    If every disk the drive is reading/writing is failing, the problem is more likely the drive than the disks.
    While I would tend to agree with you, the only 4 disks I had were all found in the trash, so....
