Results 1 to 10 of 17
Thread: obscure system attached to a fluxgate magnetometer
    May 2005
    Winnipeg, Manitoba, Canada
    447
    16
    Default obscure system attached to a fluxgate magnetometer
    came across this system recently so i rescued it curious thing it is.
    from discsions on the mailing list facebook and discord it is either part of a system that flew on planes looking for ore bodies oil and gas ect or was custom built for the usgs to mesure the magnetic feild of witch 6 systems where built that went around the world.
    https://books.google.ca/books?id=JaQ...uxgate&f=false
    seeing the case in the rack its in u would think this was some beast but then when i opened it its a single board with a analog to digital converter mounted to it and a psu to one side plus a Keytronic keyboard on the front of it and display
    back side of the rack
    inside the computer case
    hidden under the DAC board is a motorola MC6800L cpu dated 76 and a cluster of mostek ram chips date codes of 1975 and 76. not sure whats on the intel eproms.
    inside the fluxgate box
    this is prolly one of the more obscure things ive come across and happy to give it a home.
    the very bottom of the rack has something like a pdu controllor with a nob thats got 6 settings for different x and y z modes?
    Pegcity bits the home of praire bits and bytes a heritage lost yet not
    Heathkit h89 h77 h11 h10 with some extra bits
    Osborn 1 x2
    pdp8a with asr33 and documentation and software
    GE workmaster with series six PLC and ibm p70 (same as a ge workmaster 2)
    Commodore PC-10 II and other stuff
    Mar 2016
    Georgia, USA
    650
    I'd cover those EPROMS asap. Might be REALLY hard to replace.
    May 2005
    447
    16
    look like been that way for 40yrs
    Osborn 1 x2
    Mar 2016
    Georgia, USA
    650
    Quote Originally Posted by 1ajs View Post
    Yeah in a closed case, right? Not open and exposed to light, I presume.
    Feb 2017
    Guildford, U.K.
    440
    The closest I could come to B. Holland Associates is the B. Holland Enterprises Inc. of Colorado:
    https://opencorporates.com/companies/us_co/19871370826
    Yes, but what kind of light?
    May 2005
    447
    16
    led's in my house
    Osborn 1 x2
    led's in my house
    LED's have virtually 0 UV of any type. Florescences have some but not much UVC gets through the coating or the glass. Incandescences have almost 0 at the right frequency.
    The EPROM would likely leak down 100s of times faster than any ordinary light. The energy needed to cause the tunneling that would erase the EPROM, requires a threshold energy level. If you don't understand that, look up "einstein photoelectric effect". Only photons of the right energy level will cause loss of data. LEDs have a sharp cutoff in frequency of the light emitted.
    May 2005
    447
    16
    good to know might pull em see if anyone wants to recover the data off them
    Osborn 1 x2
    What uP is it. It looks to be a Motorola. Is it a 6800?
    It was clearly part of a larger system. All the terminal strips make that clear.
    It is missing the flux gate coils. I'd guess they would be on a remote location. One can make flux gates with cores that are easily saturated. RF core often are easily saturated.
