Results 1 to 3 of 3
Thread: RAM Type for DEC3000-300 Alpha Workstation
    Default RAM Type for DEC3000-300 Alpha Workstation
    Dear all!
    I have an Alpha DEC3000 here running OpenVMS 7.3 AXP and I would like to upgrade my RAM. The system Board has 8 PS/2 type (72 pin) sockets and I am wondering if I need special DEC RAMs. In the System Programmer's Manual I have found some hints (like 70ns, Parity, max 32 MB, 2 RAM SIMMs of the same type) and the DEC order number "MS16-DA" but no clue on which type actually may work or if the SIMMs are a special DEC type.
    Maybe someone hast experience here...
    Thanks and best regards
    Stephan
    Apr 2010
    Berzerkeley, California, USA
    12
    The 3000 model 300 variants, unlike all the other models in the family, use off-the-shelf 8MB or 32MB 72-pin SIMMs with parity. The same 32MB SIMMs I used in SGI Indigo 2's work in the 3000/300LX, for example. One SIMM part number that should work is HP D4893A.
    Good luck!
    "Chaos will ensue if the variable i is altered..." - SysV Programmers Guide
    Quote Originally Posted by smj View Post
    Good luck!
    Standard PS/2 SIMMS with parity just work fine, thanks a lot!
