Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: 8088/8086 microcode disassembly
    Default 8088/8086 microcode disassembly
    Using Ken Shirriff's beautiful die shots, I've reverse-engineered the format of the microcode ROM in the Intel 8088 and 8086 CPUs and disassembled it: https://www.reenigne.org/blog/8086-m...-disassembled/ . Remarkably, I've uncovered some undocumented instructions which nobody seems to have noticed in the more than 42 years since the 8086 was released!
    35,121
    Nice work!
    Amazing! Does this mean you're going to make a microcode level emulator?
    I'm definitely going to use this to improve my 8088 emulator. I don't think I'll interpret the actual microcode instructions (that would be slow), but I do plan on structuring the emulator to work the same way that the microcode program does (in terms of which opcodes share code, what the subroutines are - things like that). That should simplify it substantially.
    Mar 2011
    Atlanta, GA, USA
    1,618
    I /bow down.. I'm not worthy!
    that's nice work
    6,833
    Quote Originally Posted by reenigne View Post
    Good to see that you didn't reveal to the world the undocumented divide-by-zero instruction, an instruction added at the request of certain government agencies, an instruction that results in the 8088/8086 quickly heating up to the point of destruction (and burning a hole through the motherboard).
    The world is not yet ready for a singularity on every desktop!
    35,121
    Is the REPZ MUL complementing specific to the 8086/8088. Trying it on several later CPUs causes the REP to be ignored.
    e.g.
        MOV     AX,3
        MOV     BX,2
        REPE
        MUL      BX
    Always returns AX=6 on later CPUs. Haven't tried it on a V20/V30 yet.
    Probably! Any CPU that doesn't use the same microcode program is extremely unlikely to have the same behaviour - reusing the REP flag to mean "negate" (and not resetting it at the start of the multiply and divide operations) is not a particularly obvious design choice. I'd be surprised if it worked on V20/V30 as well - they have significantly faster multiplies so certainly an entirely different microcode routine.
