Results 1 to 10 of 14
Thread: RTC Stopped Ticking on my 286 clone board when power is off
    Default RTC Stopped Ticking on my 286 clone board when power is off
    No, the battery is not dead.
    When the power is on, the RTC keeps good time (tested with checkit). When the power is off, the clock just freezes and doesn't advance. CMOS settings are never lost. I realize that these are the exact symptoms of a weak battery, but the 4xAA external battery pack I'm using still shows 6.5V open circuit voltage.
    The board is a Shuttle 12MHz 286 board based on the VLSI 100 chipset. It is almost identical in layout and design to this comically overpriced Biostar:
    https://www.ebay.com/itm/BIOSTAR-MB-...M/123543534170
    When I first acquired this system a couple of years ago, I removed the onboard rechargeable battery before it leaked, so battery damage is not a factor. I then fitted it with the external battery box and it has been working reliably ever since, keeping good time. About a month ago I noticed the RTC had stopped working during power off. I am using 4x Energizer lithium AA batteries, which I recently learned have an open circuit voltage slightly above 1.5V. I am slightly concerned that 4 of them in series was just enough above 6V to over volt something and damage it over time. I don't think the RTC chip itself is damaged, since it still keeps perfect time on main power. I measured the Vdd pin of the RTC when the system power was off and the battery was connected and got 2.4V, which explains why the thing isn't ticking since it requires a minimum of 3V.
    Any thoughts?
    The RTC isn't really in use when an OS like DOS/Win9x is running. The OS is taking care of the time in that case. I have some systems with the same issue, because they have their 3.6V rechargeable battery replaced by a 3V coin cell, which has enough voltage to power the CMOS, but not for the RTC. When the system is running, the time advances, but is frozen otherwise. This is easy to see in the BIOS. If the clock is frozen there as well, the voltage is too low or the RTC chip is dead. If it was working before in your case with the 4 AA batteries, it's probably the latter.
    As I said in the OP, I used checkit to verify that the RTC is ticking while the system is on
    And you know for 100% that checkit really tests the hardware RTC and not just the time reported by the OS? The RTC gets its power from the battery all the time, no matter if the system is on or off. So it's either working all the time or not at all.
    And what about the BIOS? Does it work there or not? That's the only place where you can see the RTC doing its thing.
    Yes, checkit has a specific "RTC test" where it shows the real time clock output along side the DOS clock to compare them. It ticks in the BIOS as well. I believe I have located the problem - the diode immediately downstream from the external battery header is failing a diode test in circuit
    You replaced the rechargeable battery with a 6V battery pack just like that? No diode between the pack and the board?
    Next question: what is the voltage of the pack when in use?
    www.baltissen.org
    No lol the board came with an external battery header
    OK, then still my last question stands. What about replacing the RTC IC? IMHO it is a common available MC146818A. If the problems stays after replacing the IC, the problem are the batteries IMHO.
    www.baltissen.org
    The battery pack still reads 6.5V in circuit
    6,831
    I am using 4x Energizer lithium AA batteries, ...
    Like as shown at [here], when the RTC chip is powered by battery, the voltage drop across the diode (a diode that is forward biased) is quite small (actual voltage dependent on diode type and curent). If you are seeing a voltage drop that is significantly larger, then the diode is suspect.
