Thread: Wanted AMPRO Littleboard Z80 System images
    Default Wanted AMPRO Littleboard Z80 System images
    I'm looking for an AMPRO littleboard CPM 5.25" SINGLE SIDED disk image.
    I have the doublesided image on a working system, but this hardware has 2 SS drives.
    If anyone has the actual floppy I can make the image.
    35,173
    If nobody steps up, I'll have a look in my archives.
    Mar 2013
    Chaffee, MO
    1,561
    The Original Floppy has most of these files. I'd have to check my OEM Floppy. Which do you want copied to the SS/DD version?
    $ cpmls -f amp2 -D SYSTEM1.RAW
         Name    Bytes   Recs  Attr     update             create
    -A60101 .G       2K      1
    48TPI   .COM     4K     32
    ALIAS   .COM     4K     30
    AMPRODSK.COM     6K     33
    ASM     .COM     8K     64
    CONFIG  .COM     6K     48
    CRC     .COM     6K     41
    CRC     .CRC     4K     21
    DATE    .COM     2K      6
    DATE    .DOC     4K     17
    DDT     .COM     6K     38
    DIFF    .COM     4K     25
    DIR     .COM     2K     16
    DISK7   .COM     4K     32
    DOS     .COM     8K     64
    DOSFMT  .COM     6K     41
    DUMP    .COM     2K      4
    ECHO    .COM     2K      4
    ED      .COM     8K     52
    EDRIVE20.ASM    16K    125
    ESET    .COM     6K     40
    FRIENDLY.COM     2K      8
    FRIENDLY.TXT     4K     21
    GENERIC .Z3T     2K      1
    LDR     .COM     4K     22
    LOAD    .COM     2K     14
    M7LB-31 .ASM    18K    130
    M7LIB   .COM     2K     15
    MCOPY   .COM     6K     34
    MDM740  .COM    20K    150
    MENU    .COM     6K     33
    MENU    .MNU     2K     15
    MOVCPM  .COM    16K    128
    MULTIDSK.COM     8K     53
    MULTIFMT.COM     6K     44
    MYTERM  .Z3T     2K      1
    PATH    .COM     2K     10
    PIP     .COM     8K     58
    SAK     .COM     2K      8
    SD      .COM     2K     16
    SET     .COM     4K     23
    STARTUP .COM     2K      8
    STAT    .COM     6K     41
    SUBMIT  .COM     2K     10
    SWAP    .COM     4K     24
    SWAPCOPY.COM     4K     23
    SWAPCOPY.DOC     4K     17
    SYSGEN  .COM     2K     14
    TCMAKE  .COM     6K     48
    TCSELECT.COM     4K     22
    TIME    .COM     2K      5
    TIME    .DOC     4K     18
    UNERASE .COM     2K     13
    UNSQ    .COM    12K     96
    V1BIOS  .HEX     8K     53
    WHEEL   .COM     2K     11
    XSUB    .COM     2K      6
    Z3INS   .COM     2K     15
    Z3TCAP  .TCP    10K     66
    ZAMPRO0 .DOC     2K      6
    ZAMPRO0 .ENV     2K      2
    ZEX     .COM     6K     40
    ZMOVCPM .COM    16K    128
       63 Files occupying    330K,      56K Free.
    Larry
    Oct 2011
    Bedford, NH, USA
    1,643
    Just on the off chance this may help - have you seen this on eBay:
    https://www.ebay.com/itm/1980-85-Amp...gAAOSwWlVcLnK5
    Not mine. Just trying to help out, if I can. I see one of the disks is labelled as double sided, but others are not.
    smp
    Mar 2013
    Chaffee, MO
    1,561
    I took my original file *.DMK (used cwd2dmk and my Catweasle M4 to create the .DMK) and converted it to .IMD. And got the directory listing:
    $ cpmls -f amp1 -D AMPRORIG.RAW
    -A60014 .E       2K      1
    AMPRODSK.COM     4K     30
    ASM     .COM     8K     64
    CONFIG  .COM     6K     38
    DDT     .COM     6K     38
    DIR     .COM     2K     16
    DISK7   .COM     4K     32
    DUMP    .COM     2K      4
    ED      .COM     8K     52
    LOAD    .COM     2K     14
    MOVCPM  .COM    12K     96
    MULTIDSK.COM     6K     47
    MULTIFMT.COM     6K     41
    PIP     .COM     8K     58
    STARTUP .COM     4K     30
    STAT    .COM     6K     41
    SUBMIT  .COM     2K     10
    SWAPCOPY.COM     4K     18
    SYSGEN  .COM     2K     11
    UNERA   .COM     2K     16
    WELCOME .MSG     2K     16
    XSUB    .COM     2K      6
    ZMOVCPM .COM    12K     96
       23 Files occupying    110K,      78K Free.
    So, these are the actual files on my OEM Floppy. Send me a PM with your Email address.
    I assume you can write .IMD files?
    Larry
