Results 1 to 7 of 7
Thread: Debug flags in Simh
    Default Debug flags in Simh
    Hi ,
    I am playing with debug and Simh. I succesfully debug RL device using
    SET RL DEBUG
    Now I would like to debug DL but
    SET DL DEBUG
    not working
    I also tried
    SET TTI DEBUG
    SET TTO DEBUG
    My goal is to sse what is write and read in DL registers, and if possible to see DL interrupts .
    Thanks for help.
    Aug 2010
    Silicon Valley USA
    880
    4
    Try:
    SET DLI ENABLE
    SET DLO ENABLE
    SET DLI DEBUG
    SET DLO DEBUG
    works for secondary DL11 interfaces at 776500++
    Thanks but Unfortunately it doesn't work .
    I can see DLI and DLO are enabled using SHOW DEVICES but DLI DEBUG returns "Command not allowed"
    Any other idea ?
    Aug 2010
    Silicon Valley USA
    880
    4
    Quote Originally Posted by Activmaker View Post
    Any other idea ?
    So...
    ~[501] pdp11
    PDP-11 simulator V4.0-0 Current        git commit id: de6db584
    sim> set dli en
    sim> set dlo en
    sim> set dli lines=1
    sim> sho dli debug
    Debugging disabled
    sim> set dli debug
    sim> sho dli
    DLI     address=17776500-17776507, vector=300-304*, BR4, lines=1
    sim> sho dli debug
    Debug=REG;INT;XMT;RCV;RET;MDM;CON;ASY;TRC;EXP;SEND;XMTPKT;RCVPKT
    sim>
    Don't know of any valid command DLI DEBUG
    Hi,
    Sorry I made a typo in my last post. I used SET DLI DEBUG , and not DLI DEBUG as I wrote. But your post gave me the answer. I was using Simh 3.9 not 4.0.
    With 4.0 , SET DLI DEBUG is working.
    But now, as debug works with secondary DL11 , how can I see the DL11 sequences when RT11 is booting ? Should I "connect" with a second computer by serial port to the Simh Host ? ..Or maybe there is a easier solution. Maybe it is not possible..
    Aug 2010
    Silicon Valley USA
    880
    4
    Hi,
    Yikes. v3.9 is REALLY old now.
    From reading the pdp11_stddev.c code, and trying it in simh, SET TTI DEBUG and SHOW TTI DEBUG works.
    Unfortunately (do to a coding oversight, I suspect) the equivalent for SET TTO DEBUG and SHOW TTO DEBUG are not implemented, and thus does not work.
    So really if you absolutely need debug status on TTO console output, you need to submit a bug report on SIMH that debug mode for PDP11 console terminal output is not implemented.
    Or, implement it in pdp11_stddev.c yourself and submit it as an update to the sources. Assuming you are interested/capable of using github to do this.
    Hi,
    Thanks for your comments . I started using SET TTI DEBUG , but looks like that memory is corrupted before RT11 start trying to communicate with DL11 (I am talking here of my system not Simh, I use Simh with debug to compare activities of my system and Simh) . I need first to debug and found the reason of corruption (RT11 use EMT during boot , and I found that the vector 30 used for EMT is lost during the boot ).
    So maybe, one day I will need to modif simh to get TTO DEBUG working, but for now , it is a little bit early.
