Page 1 of 4 1234 LastLast
Results 1 to 10 of 34
Thread: What do you call these female connectors?
    Jan 2012
    Connecticut, USA
    3,076
    Default What do you call these female connectors?
    Need to build a cable that has one of these female connectors at both ends but I dont know what they are called. Apple-III-Cable-400x400.jpg I need either 10 or 11 pin variants
    Thanks guys
    Mick
    Jun 2014
    Salt Lake City, Utah
    554
    Spread the joy of Vintage Addiction
    -->www.chronworks.com/<--->www.i8008.net/<--
    Jan 2012
    Connecticut, USA
    3,076
    Thanks 8008guy, I think you got it right. I found these: https://www.ebay.com/itm/QTY-10-1-64...0AAOSwq7JT8Th0
    but how do I measure pitch? I dont want to just keep making purchases till I find one that fits. I was looking through what I had but most of these connectors are too large. Here is the connector on the board vs one I thought I could use from a MAcintosh LC power supply (that was too big, pins were a much larger gauge) Attachment 63637
    May 2018
    Lancashire
    645
    The ones linked are a pitch of .1" or 2.54mm so just measure the distance between two of your pins and see if they are about 2.5mm apart.
    Current fleet
    TRS80 Model 4 - BBC B - Tatung Einstein - PCW9512 - PET 3032 - C64 - ZX81 - Spectrum 48K - Amiga A500 - VAX 3100,3300,4000VLC & 4000 Model 96 - Apple II europlus - Apple iMAC G3. Sharp MZ-80K. - DEC Micro PDP 11/73 - IBM 5160 XT - Multibus 286/10 - Alpha server - MicroVax II.
    Jan 2012
    Connecticut, USA
    3,076
    Thanks Gary, now where is my only micrometer?
    35,117
    If you can't find it, look at the spacing across 11 pins (pin to pin) should be about 1 inch. 6 pins should be about 1/2 inch.
    (25.4 mm = 1 inch).
    Jan 2012
    Connecticut, USA
    3,076
    Thanks Chuck If I don't find my micrometer I will try that out.
    May 2018
    Lancashire
    645
    (25.4 mm = 1 inch).
    Oh, lateral thinking !
    Love it
    A simple rule in mm should suffice though if they are about 2 and a bit mm apart, they will be 0.1"
    Current fleet
    35,117
    Just trying to think locally. I have several tape measures and rulers and I don't think any of them has a metric scale.
    I rely on my mics calipers for that.
    Jan 2012
    Connecticut, USA
    3,076
    Of course I see my micrometer all the time when I dont need it, and its not the in correct places... So Ruler it is! 20200924_124948_resized.jpg
    Hope this comes through. its just a hair over 2mm per pins and it looks pretty much dead on 1cm between pins one and three.
    Edit: Don't know why the attached photo on my second posting went invalid but this is the image: mta.jpg
