Results 1 to 4 of 4
Thread: Need information on an old DELTA AT type supply OEM IBM
    Sep 2003
    Ohio/USA
    8,095
    Default Need information on an old DELTA AT type supply OEM IBM
    I have a Delta Electronics DPS-145PB-72 A rev 01
    IBM P/N 76h4855
    FRU 76h4856
    EC E71692
    150W
    It has 3 of the AT type power connectors for the motherboard and no on/off switch (unless a small 3 wire motherboard plug is the on/off).
    35,152
    It sounds like some of the older HP Delta PSUs that I have with the 3-pin fan speed cable.
    Sep 2003
    Ohio/USA
    8,095
    Reminds me of the supply I seen in an IBM dual PPro desktop where 2 power leads went to the motherboard and one to the riser card complex (before they all went to ATX supplies i guess).
    35,152
    Yeah, until ATX it got to be anarchy wrt power cables. example. Even post-ATX some of the Compaq workstation connections were sui generis
