Results 1 to 2 of 2
Thread: SGI Indigo2 Power Supply Repair Service
    Default SGI Indigo2 Power Supply Repair Service
    I have a number of Indigo2 power supplies that need to be repaired.
    It's certain recapping is required, but some additional debugging may potentially be required.
    I have not had much luck finding a technician. Might someone here have pointers?
    2,221
    I do recapping if you need it done. I can do some basic poking around to see if the power rails are putting out the correct voltage and such.
