Results 1 to 3 of 3
Thread: PDP-8/F Quick look and Teardown
    Jan 2019
    88
    Default PDP-8/F Quick look and Teardown
    Leaving the best to last, here is the pride of my PDP collection, the PDP-8/F.
    Here we just open it up and have a look around. The power supply and its capacitors still need to be
    tested before I'll try to turn it on.
    https://www.youtube.com/watch?v=wAstB-dCvg8
    Nice little basic machine! Are you going to expand it to run os/8? Or even play spacewar on it? 😊
    There are a lot of boards available which you can built like a ram/bootloader to max it out to 32kw of memory.
    rx01/rx02 board for a floppy drive (or emulator of course which makes it really fast to use)
    vc8e is available for graphics, Ta8e for the Tu60 drive... you can have a lot of fun with such a little machine!
    Regards, Roland
    Jan 2019
    88
    Thanks!
    I'd eventually like to get an OS running on these machines, but my main goal at the moment is just to get the basic machine working.
    I know of your bootloader and other interfaces for disk emulation, etc.
    And one day I want to play with that sort of stuff, but I want to take a break from PDPs for a while.
