Results 1 to 7 of 7
Thread: 5160 motherboard layout
    May 2016
    Fairfield, Ohio
    486
    Default 5160 motherboard layout
    I looked around minuszerodegrees but didn't find what I was looking for, which is a simple schematic showing the layout of a 5160 motherboard. Modern motherboards come with such schematics (USB header, parallel port header, etc) but I haven't seen one for the 5160. Mind you there's not much there compared to a modern machine, but it's nice to know.
    Does anyone know of such a schematic?
    3,596
    I'm guessing this is the sort of thing you are thinking of: http://www.uncreativelabs.de/th99/m/I-L/30485.htm
    Pedantically, that is not a "schematic".
    just google for "IBM 5160 board" and you get quite a lot of pictures that you can use, IMHO. If not, PM me and I make you a nice high res photo that gives you enough details to see where all ICs are seated.
    www.baltissen.org
    May 2016
    Fairfield, Ohio
    486
    You are correct. Schematic is not a good word.
    The link you provided is sort of what I'm looking for, but I'm also interested in where the keyboard controller is, the timing crystal, stuff like that. A call out of where the major chips are located on the board.
    3,596
    For that much detail, you are probably looking for a layout diagram. Those often do accompany schematics. I don't recall if the IBM technical manuals had those, but things like the SAMS PhotoFacts would have those with their schematics.
    Be sure to check out http://www.minuszerodegrees.net/ you might find something like what you are looking for there. Piles of information about IBM 5150/5160/5170s and so on.
    Sep 2020
    Wellington, New Zealand
    23
    Get yourself a copy of the IBM PC XT Technical Reference (available at minuszerodegrees.net) and turn to pages 1-6/1-7 for a logical block diagram of the system board and page 1-13 for an illustration of the physical board with a couple of the chips identified. Otherwise just get a good clear photo of a 5160 board to refer to as you browse the schematics: it's not a particularly complex board and each chip is clearly labelled on the board itself and also clearly identified in the schematics.
    May 2016
    Fairfield, Ohio
    486
    Haven't gone through it in detail, but it seems packed full of juicy info. Thanks!
