Results 1 to 10 of 28
Thread: MicroVAX 3300 TK70/50 Tapes
    Sep 2020
    Millmeece Near Stafford UK
    13
    Question MicroVAX 3300 TK70/50 Tapes
    Has anyone got or could loan me some diagnostic or Vax/UNIX software on TK70/50 tape media so that I can fix myMicroVAX 3300.
    This computer will start up but not boot VMS (NB. This is not surprising as it has not been run for about 25 years). I suspect I will need to swap The drives around and then reload VMS or UNIX.
    NB. This is one of the DEC computers that is part of my collection www.museumofcomputing.com based in the U.K.
    Feb 2011
    2,506
    10
    Does it have a network interface? You could do a network boot? If you have a working DSSI drive I could copy some install media? Are you on the DEC Legacy list. Its UK based.
    G4UGM
    Sep 2020
    13
    Yes it does have an Ethernet interface.
    Do you think it could be used to do remote boot via the Internet ?
    I assumed it could only use Decnet.
    Feb 2011
    2,506
    10
    I think the 3000 has a battery. If its flat it may be trying to boot from the network. What do you see on the console?
    You can't boot it from the internet, but you can boot it from an Infoserver on SIMH instance running on a PC.
    .... this was discussed on cctech mail list
    http://www.classiccmp.org/pipermail/...st/055190.html
    and Matt @ 9track has info on setting up the infoserver here...
    http://9track.net/simh/infoserver
    G4UGM
    Sep 2019
    Zurich, CH
    221
    Quote Originally Posted by SteveG View Post
    It's not that black and white. The initial boot request from the firmware is using MOP. But there are MOP servers for Unix. Once you've downloaded the initial image, what happens then is totally dependent on that image. NetBSD on VAX for example, does the initial boot via MOP, next step is using bootp and then nfs.
    But if you plan to boot VMS, then I suspect it will be much more MOP, and eventually actual DECnet protocols.
    Sep 2020
    13
    Default Screen Shots
    The MicroVAX tries from DIA0: and fails to find the device. Could this be because the disk has been formatted to remove any data before giving it to my museum?
    Sefton, Meresyside, England
    424
    Can you type,
    Boot DIA0 or Boot DIA1
    I don't see it attempting to boot either disk on the screenshot
    Sep 2020
    13
    Default Another Screenshot
    Quote Originally Posted by PG31 View Post
    Can you type,
    I have not tried to boot from DIA1
    Is the DSSI Terminator in place?
    Sep 2020
    13
    Default DSSI Terminator
    Quote Originally Posted by Schroeder View Post
    Yes you can see that in the image below.
    There appears to be 3 RF30 discs. One on the main cabinet and 2 in the expansion box and yet the MicroVAX firmware only detects 2.
