Results 1 to 2 of 2
Thread: Need software for Grammar Engine PromICE
    San Antonio, TX
    Default Need software for Grammar Engine PromICE
    I have three of these that I accumulated over the past decade from lucky thrift store finds. I finally got them talking tonight so now I need the software for them. I'd like to have the C source code to the "loadice" utility. Does anyone here have it?
    FWIW, they are a 256K unit with v5.3a firmware, a 256K with v5.2d, and a 64K+64K (16-bits yeah!) with v4.1a. Next step is to see if I can put in bigger RAM chips, then build some ROM cables. The command-line serial interface is clunky, but it's good enough to verify operation.
    Nov 2007
    minneapolis, MN
    1,376
    Your thrift stores sounds WAY better than the ones up north if you can find these things.
    here's version 3.2a:
    http://www.waste.org/~winkles/loadice.zip
    I have two complete units with manuals, software and a couple cables that my workplace retired. I only need one of them if you want to expand your empire.
