Error during startup:
"Bad RAM at 8075D = 00h, expected = 00h."
Which is the ram memory? Where to look for the cause?
First, be aware that I am unfamiliar with the Commodore PC 20-III.
Maybe someone who is will 'chime in'.
From information on the Internet, I see:
* The PC 20-III is simply a PC 10-III with a hard drive added. ASSUMPTION: From that, the two motherboards are the same.
* 640 KB of RAM
"Bad RAM at 8075D" equates to address 526173, approximately 514 K.
That fits with the displayed "512 Kbytes OK"; that is, at least 512 KB of the fitted 640 KB is okay.
From what I make of the technical information online:
RAM bank 0
256 KB sized, addressed 0 to 256K.
Eight 41256 type RAM chips, each providing 1 bit.
No parity bit.
U312 = bit 7, U311 = bit 6, U310 = bit 5, U309 = bit 4, U308 = bit 3, U307 = bit 2, U306 = bit 1, U305 = bit 0
RAM bank 1
256 KB sized, addressed 256K to 512K.
No parity bit.
U320 = bit 7, U319 = bit 6, U318 = bit 5, U317 = bit 4, U316 = bit 3, U315 = bit 2, U314 = bit 1, U313 = bit 0
RAM bank 2
64 KB sized, addressed 512K to 576K.
Two 41464 type RAM chips, each providing 4 bits.
No parity bit.
U321 = bits 7/6/5/4, U322 = bits 3/2/1/0
RAM bank 3
64 KB sized, addressed 576K to 640K.
No parity bit.
U323 = bits 7/6/5/4, U324 = bits 3/2/1/0
When I first saw that, I thought to myself, "That will be just like the POST in the IBM PC; if no data bits are reported as faulty, it means that it is the parity bit that has failed."
But when I looked at the circuit diagams for the PC10-III/PC20-III motherboard, I could not find RAM for parity. The motherboard's FE2010 chip supports motherboard parity, but I see that the FE2010's PTYIN pin (pin 32)(FE2010 datasheet: "Parity bit from parity RAM") is grounded. The FE2010's PTYOUT pin (pin 33)(FE2010 datasheet: "Parity bit to parity RAM") is routed through driver U108, but I cannot see it after that. So, because the FE2010's PTYIN pin is grounded, the POST in the PC10-III/PC20-III motherboard must be disabling parity checking by the FE2010, via bit 4 of the FE2010's control register.
With no RAM parity bits, the "= 00h, expected = 00h" puzzles me. If the POST wrote 00h to address 526173 and then read back 00h, what mechanism informed the POST that there was a "Bad RAM" problem at that address?
FINE.
I ordered the MSM41464-10 RAM (+socket dil1to start.
I will replace the RAM. I will write what the test showed.
Ram replaced. Bad ram is still there.
I read the diagram again. I checked the connection for 2 hours.
I found one more error.
U325 -> U109
I fixed the connection. Works correctly. I have 640Kb RAM ... YUPI
Thank you all![]()
