Results 1 to 3 of 3
Thread: Netronics ASCII keyboard and Video Board questions
    Jan 2012
    Surrey,BC,Canada
    149
    Default Netronics ASCII keyboard and Video Board questions
    Apologies for cross-posting. I finally had my hands on this Netronics products ( got it for a fair price few years ago with Explorer/85). After re-soldering ( and IPA+cleaning) all points on the PCB and replacing caps, I got the the Video board working. I also re-did the solders ( and replace the ribbon cable and ic socket) on the ASCII keyboard to get it to work with the Video board. However, I have some puzzling questions about the keyboard. I re-checked all jumper settings according to the manual but...
    1. When typing, some keys shows the characters on the screen. However, it sometimes does not. Only when I hit this ?key ( installed by original owner) in combination with the ASCII key that I can make it show up in the screen. There is no explanation ( that I found why so) from any source yet.
    2. Repitious characters depending on how fast I hit the key....like I have de-bounce problems.
    3. There is area for an extra chip +.. that was not mentioned in the manual nor shown in the schematic.
    Anyway... the ?key is on J6 ( normally open) and the unpopulated parts area is near P1 ( ribbon cable)
    Would anyone has a tip for me is much appreciated.
    Oops... I have to upload my pictures from my computer ( on Ipad right now).
    Oct 2016
    Dutchess County, New York, USA
    237
    I dug out the keyboard I've used with a Netronics terminal board thinking it was the same keyboard as what you were asking for info on. However, other than using a ribbon cable to the terminal is is completely different. Looking for a description or maker on it and discovered it is a Jameco JE610 ASCII keyboard dated 1979. So sorry, can't help out.
    Crazy old guy with a basement full of Pentium 1 laptops and parts
    It is possible that it is the strobe polarity.
    Dwight
