Results 1 to 10 of 10
Thread: High Quality Sound Card for Windows 98SE
    Default High Quality Sound Card for Windows 98SE
    What's are some of the best vintage sound cards that will work with Windows 98SE on a 500 mhz P3 machine? It has several PCI slots available as well as one ISA slot.
    I will be using this strictly for audio recording, mostly digitizing old cassette tapes.
    A Sound Blaster Live! for example. Since tapes don't have "high quality" in the first place, you don't have to care that much for anything better. Most work on tape recordings is done afterwards using audio editing software anyway.
    Thank you. I'm trying to learn about sound cards in general, I'll start with the cassette tapes but will move on to my vinyl collection. Audio quality is the priority, where does the Sound Blaster Live! sit in the sound quality spectrum of sound cards?
    The Live! has a SNR of 100 dB, just like the Audigy. That's already very good for a consumer card. The Audigy 2 even had 106 dB SNR, but no idea if they made Win98SE drivers for that.
    Thank you, 100bd s/n ratio is way better than my cassettes.
    I see lots of Live! sound cards on ebay, but I'm wondering how easy it will be to get Windows 98 drivers for them.
    EDIT: I just found one here.... https://support.creative.com/Downloads/welcome.aspx
    2,215
    The last driver version Creative has on their website works fine on Windows 98, so long as you don't need to use sound in DOS programs. There's a different VxD driver that's required for DOS sound support, which is a bit hard to find.
    Thank you. No I don't need to use it in DOS.
    Sep 2003
    Ohio/USA
    8,117
    I used Aureal Vortex 2 PCI sound cards in the Windows 98 era and still do.
    Thanks. Are these Windows 98 era machines used mostly for "gaming"? Most of the info I see on the web suggests this.
    Are there any "audiophiles" using Win98 machines and software?
    Not using Win98. My audio recording system is based on Linux and using an Asus Xonar card. SNR is 116 dB with that one, but not that it would matter for tapes or vinyl records. I'm using it mainly to record from professional MIDI equipment.
