Results 1 to 10 of 12
Thread: Delsodering Cleaning Tool
    Default Delsodering Cleaning Tool
    Hey All,
    So, I have an awesome vacuum pump desoldering gun that I love, but gets clogged once in a while. It came with a .8mm cleaning tool that would clean it out perfectly. I actually lost this cleaning tool and need another one. Does anyone know a source to purchase this cleaning rod ? Everything on eBay is either the 1.3mm or the metal kit which is way to short and doesn't insert all the way (plus gets hot as it's metal). I Having trouble finding the something that will work.
    Thanks !!!
    35,369
    Should be easy to find something--what was the original made of?
    Jan 2012
    Connecticut, USA
    3,179
    Are you referring to this tool?
    https://www.ebay.com/itm/353109239001
    4,828
    Hakko sells them direct for a reasonable price. hakkousa.com is the correct site for orders placed in the US.
    Hey Chuck. The original one was metal .8mm I believe, had a plastic handle and was nice and long.
    Thanks VERAULT, but that one isn't long enough for my gun.
    Thanks glitch, I have tried on their site, but actually couldn't find any. Can you post a direct link to them ? Thanks !!
    Thanks All !!
    35,369
    You could buy a spool of 13 gauge music wire and have enough for the rest of your life and any friends. 13 ga. = 0.8mm.
    4,828
    Quote Originally Posted by MaCJaX View Post
    https://hakkousa.com/b1086-cleaning-pin-0-8mm.html
    ...but that's the same one VERAULT linked.
    This is what I am looking for. This is a 1.3mm. I need this in 0.8mm but this length and with a plastic handle. Most are too short and will not reach the tank area.
    Oct 2016
    236
    Buy the music wire Chuck suggested and cut off a piece long enough and epoxy on a scrap wood handle.
    Go to Lowe's, Home Depot, etc.... and pick up a welding tip cleaning tool.
    https://www.lowes.com/pd/Lincoln-Ele...ner/1001280970
