Results 1 to 9 of 9
Thread: Delsodering Cleaning Tool
    Default Delsodering Cleaning Tool
    Hey All,
    So, I have an awesome vacuum pump desoldering gun that I love, but gets clogged once in a while. It came with a .8mm cleaning tool that would clean it out perfectly. I actually lost this cleaning tool and need another one. Does anyone know a source to purchase this cleaning rod ? Everything on eBay is either the 1.3mm or the metal kit which is way to short and doesn't insert all the way (plus gets hot as it's metal). I Having trouble finding the something that will work.
    Thanks !!!
    35,150
    18
    Should be easy to find something--what was the original made of?
    Jan 2012
    Connecticut, USA
    3,080
    Are you referring to this tool?
    https://www.ebay.com/itm/353109239001
    Jan 2010
    Central VA
    4,818
    Hakko sells them direct for a reasonable price. hakkousa.com is the correct site for orders placed in the US.
    Hey Chuck. The original one was metal .8mm I believe, had a plastic handle and was nice and long.
    Quote Originally Posted by VERAULT View Post
    Thanks VERAULT, but that one isn't long enough for my gun.
    Quote Originally Posted by glitch View Post
    Thanks glitch, I have tried on their site, but actually couldn't find any. Can you post a direct link to them ? Thanks !!
    Thanks All !!
    35,150
    18
    You could buy a spool of 13 gauge music wire and have enough for the rest of your life and any friends. 13 ga. = 0.8mm.
    Jan 2010
    Central VA
    4,818
    Quote Originally Posted by MaCJaX View Post
    https://hakkousa.com/b1086-cleaning-pin-0-8mm.html
    ...but that's the same one VERAULT linked.
    This is what I am looking for. This is a 1.3mm. I need this in 0.8mm but this length and with a plastic handle. Most are too short and will not reach the tank area.
  9. #9
    Oct 2016
    Dutchess County, New York, USA
    201
    Buy the music wire Chuck suggested and cut off a piece long enough and epoxy on a scrap wood handle.
    Crazy old guy with a basement full of Pentium 1 laptops and parts
