Results 1 to 10 of 24
Thread: Kaypro 4-83 graphic overlay
    Default Kaypro 4-83 graphic overlay
    Hello,
    Since the Kaypro 4-83 does not have any graphic capabilities I decided to develop a small simple graphic extension board.
    The board creates a graphical 560x240 pixel overlay on top of the text display. The board has its own memory.
    Synchronization with the original video output is done by connecting some wires to a few points and lifting one pin in the video circuit of the mainboard.
    To keep interfacing simple I decided not to try and get it memory mapped but instead control the overlay board through the two unused B ports of the two Z80 PIO adapters.
    The mainboard has labeled solderpads for all the unused pins.
    By first adding some pinheaders those solder pads next to the PIO's connecting is fairly easy.
    Writing to the graphic memory is done in three steps:
    1. set X offset
    2. set Y offset
    3. write data
    All done by IN and OUT instructions to the PIO chips.
    It is also possible to read back the data from the graphic memory.
    The rather odd resolution of 560 pixels horizontal comes from the fact that the Kaypro displays 5x8 character bitmaps in a 7x10 matrix.
    So far I have made a prototype and tested with BBC basic and some small assembler routines (for speed) and the results are already quite nice.
    There are still some small glitches when writing to the graphic memory resulting in some artifacts which I hope might be solvable by synchronizing some of the outputs of the GAL 16V8 (which acts as 'logic glue' on the board).
    When the Kaypro is reset the output of the graphics overlay is disabled and the Kaypro works as usual.
    By setting a single bit to zero the graphics overlay is activated.
    The whole circuit consists of 6 TTL chips, a fast 32 kByte SRAM chip and a GAL16V8 chip.
    The (crude) schematic is attached as PDF, I will add a list of which connections go to where if anybody is interested.
    kpgfx.pdf
    some example images
    the prototype
    Gert
    Outer Mongolia
    3,057
    Nice!
    Looking at the schematic I see you have A0-A6 connected to the "X" latch and A7-A14 connected to the "Y" latch; I assume that means that the way you have the framebuffer laid out it's essentially 1024 bit-wide (128 byte) line that you're only using part of... I guess the question I'd have: Since the Kaypro natively has 7 pixel wide characters, are you using 80 bytes across and not using one of the bits in each character, or are you using 70 full bytes? ... Looking at the schematic I'm going to guess it's the first, because you're using a signal called "DCTC" as both the load signal for 74LS166 and to clock the address counters. (Which I'm guessing is pulled from the Kaypro's shift register load signal?)
    Nice!
    That is correct, the Kaypro uses a similar scheme: 128 bytes per line with 80 bytes visible, by using a clever way of wiring the address lines they still manage to keep it in 2 kBytes.
    My counters are chugging along with this scheme resulting in 128 bytes per line and by combining the HS and VS signals it blanks out the rest (by resetting the shift register)
    Yes I use 7 bits per character also, resulting in the 560 pixels horizontal resolution.
    /DCTC is the character clock (inverted) taken from pin 1 of U6, it also latches the parallel input of the 74F166 shift register
    TC is the non inverted signal coming out pin 15 of the pixel counter U1 (both signals are also available on U4)
    I needed both edges for the 74HC590A counters (one to count and one to latch the output register)
    The 13.9 MHz signal taken from pin 8 of U2
    The HS signal is coming from pin 8 of U32 (aka A10 of the character rom), VS is taken from solder pad E4
    Data lines KP_D0 to KP_D7 are connected to solderpads E14 to E7 (U52 PIO)
    /ENA is connected to E18 (U52 PBRDY line, it pulses for every data byte written to port B of the PIO)
    Solderpad E16 (U52 /PBSTB) is connected to ground (this gives the shortest pulse on E18, about 500 ns on my 5 MHz clocked Z80)
    LDLO connects to E29 (PB0 of U72) when high selects the X latch
    LDHI connects to E28 (PB1 of U73) when high selects the Y latch
    KPWR connects to E31 (PB2 of U73) when writing this signal is high, reading is low
    /VON connects to E34 (PB7 of U73) when low the graphic overlay is enabled, it is pulled high with a 10k resistor so when the Kaypro is reset the overlay is off.
    Port B of U73 is used in mode 3, that leaves the other pins open for either in- or ouptut.
    /GFX_OUT from the GAL is fed into (the lifted) pin 5 of U15
    In my prototype I used a 20V8 GAL and the equates are here (turned out a GAL 16V8 can handle all the signals also)
    None of the outputs of the GAL are synchronized (yet) and could explain the glitches I sometimes see.
    In the new circuit I have made provision to synchronize with either /DCTC or TC but have not tried this yet.
    BTW reading from the graphic memory needs an extra dummy 'IN' instruction because of the odd PBRDY/PBSTB handshake the PIO does when the port is in input mode.
    Outer Mongolia
    3,057
    Quote Originally Posted by gertk View Post
    I'm really curious how they did that, I'll have to see if I can dig up the schematic.
    I've been working on my own video project, a from-scratch video card intended to emulate early S100 video cards like the Polymorphic VTI or Solid State Music VB1B (or a TRS-80's built-in video) in addition do doing full bitmap graphics, and a working constraint I initially adopted was having the memory for each video line having to be a power-of-two in width because it simplifies a number of things significantly. (Which is why 64x16 was a popular video format for a couple years.) I didn't know when I started that apparently that same constraint secretly applied to some early 80 column cards as well. The Kaypro's apparently another example.
    I assume the glitches are the normal "hash" you see on video systems that don't arbitrate the CPU with wait states when the video memory is being accessed by the video out circuitry? (IE, like a TRS-80 Model I or an original IBM CGA card.) I'm not sure how you'd solve that without generating wait states or using dual-ported memory.
    Most of the glitches/artifacts occur on the leftmost column and the pattern is often the same: 1010101 (and it gets stored into RAM)
    There is also some (barely visible) hash during the writes but that was expected, the Kaypro video circuit has the same 'problem'
    The timing is quite critical I guess as the write signal, /RAMWR, and the outputs of the latches and buffer are only active during the low portion of the /ENA signal (PBRDY).
    Might be violating the timing rules of the SRAM a bit here
    I did use a very fast SRAM chip (I have a whole bunch of the old 32 kByte PC cache rams of 15 and 20 ns in the 'skinny' DIP28 format)
    Below I attached the schematics for the IO/Video and CPU circuits of the Kaypro 2 & 4-83.
    kaypro4_83_cpu.pdf
    kaypro4_83_io.pdf
    kaypro4_83_video.pdf
    P.S. It seems I have left out the logic equation for the /LOE and /CNTRES signals in the image, but they are as follows:
    ' COUNTER RESET '
    CNTRES = VS;
    CNTRES.OE = OE;
    'LATCH and BUFFER OUTPUT ENABLE, active only when reading or writing data '
    LOE = ENA * !LDLO * !LDHI
    LOE.OE = OE;
    I posted the circuit diagrams of the CPU, IO and Video circuit of the Kaypro above.
    Also tried to (RC) delay the output enables of the latches and buffer but it makes no difference.
    Maybe I need to toggle the /CS or /OE of the SRAM but then I need to have an output on the GAL...
    The video output inversion can be skipped as there is a spare NAND port on U5 available.
    For blanking the output I can also use the shift register reset output freeing up one output on the GAL.
    Outer Mongolia
    3,057
    Just took a look at the Kaypro's video schematic, and I have to admit I'm stuck scratching my head why they used a six bit edge-triggered latch plus an 8:1 multiplexer instead of a shift register for dot generation, but I guess there's no reason why that wouldn't work?
    I think I'm a little thick this morning to work it out, so I have some questions about what you've learned from driving the shift register!
    First: You're driving the Load pin (and clocking the GAL) with a once-per-character pulse from the Kaypro's motherboard? My dumb question, since it's a thing I actually haven't tried yet with the video dingus I'm building: the characters in this machine are 7 bits wide. When a character is less than 8 bits does triggering a load automatically make the next bit clocked out bit0 again, or are you having to trigger a clear on the shift register? It doesn't *look* like you are with the GAL code.
    Second: I'm curious, do you really need to work the clear input on the shift register? (And if you do I'd genuinely like to know why, in case it's a thing I need to worry about.) On the thing I'm building at first I thought I needed to use either the CE/Inhibit input or the clear input on the shift register to keep it from outputting recirculated data when I was outside the active video area, but then I realized if pin 1 was tied low like you have it'd just clock out an endless string of zeros when it wasn't within 8 cycles of the last load command. But maybe there's something about the overlay or cooperating with the Kaypro's native circuitry that makes you need it?
    In case you're curious at all I'm using a GAL on my project too; I'll probably be using at least one other because the thing I haven't tackled yet is the memory arbitration, which may well run into whatever issues you're having. (I'm likewise intending to use a fast 32k SRAM; I have a couple 35ns Cypress parts on hand that I hope are fast enough to do the needful, but right now the prototype is just generating fixed content from a 70ns flash chip) The GAL that's in there now is clocked at the pixel clock (12mhz) and four of the outputs are set up in registered mode as a 4-bit counter that I can hold in halt/reset or allow to free-run. Address generation is done by an AVR 8-bit CPU running synchronously at the pixel clock, and the shift register load signal is generated by the GAL based on that counter, which I start free-running at the start of each active line area. (That frees up instructions otherwise needed to toggle the shift register so I can do more per character while still giving a predictable cadence so I can prevent doing the address loads that would unsettle the memory output when the load is going on.)
    What a marvelous vintage computer project. I really like those fractal graphics, well done !
    No idea why they used this elaborate concept, also using a 4 bit counter starting at 9 to get 7 dots effective, then only using 5 bits from the rom, scanning 10 lines per character vertically and use only 8... A10 and the enable pin(s) of the rom are also used for blanking. The character counter is running from 0-127 and 0-79 are visible (maybe that way it was easier to generate the horizontal timing)
    Yes, parallel loading the shift register is shifting bit D7 (input H) out first so that way it stays in sync with the 7 bit width scheme. I'm keeping the shift register reset during the blanking (vertical and horizontal) otherwise the data keeps on going for all 128 bytes and I get retrace problems. The serial input can either be tied to ground or Vcc since the shift register never gets to the bit from input A (aka D0)
    To keep the screen from getting overlayed with random data during startup (making the Kaypro's own video unreadable), I keep the video output disabled until 'switched on' by the /VON input.
    The graphics ram can then be cleared (or written) first and then switched on. At the moment I am using the /VON in the graphic video inverter stage of the GAL.
    The /W output of the Kaypro video multiplexer U41 is fed into the NAND gate U15, used as inverter, by lifting pin 5 I have an extra input for my graphic video but it needs to be inverted too
    When using 8 pixel wide characters there is no need to reset the shift register as every 8 pixels you need to clock in new data anyway, by tying the serial input low you can leave the dotclock running during blank, just stop the parallel load from happening and it will work fine.
    Arbitration is the hardest part. You need either a synchronous system of video and CPU (as can be done with the 6502 for example: first half of the CPU clock is video access, second half is VIDEO access) but with a Z80 you either have to add waitstates or use some other clever technique.
    I have thought of the following:
    The CPU writes data and address to some latches and then the video circuit handles the writing (synchronously with the character clock)
    With a fast SRAM chip this should be doable.
    You have a 12 MHz dotclock and it gets divided by 8 for your character clock so your time per character access is 1.5 usec. By using the 'other edge' of that character clock you could write the data from the latches into the SRAM without disturbing the reads (which would happen on the leading edge of the clock). If the CPU has an access time of less than 1.5 usec there would be no contention. If the CPU is faster you could add fixed time as waitstate for the video memory range (or uses some NOP's before accessing the video ram again)
    You do need a flipflop set by the writing of the latches by the CPU which indicates that writing is needed, and is reset by the actual write by the video circuit.
    Otherwise the video ram will be filled with the same data over and over...
    Outer Mongolia
    3,057
    ... I was about to say I'm still a little confused, but I think I get it? I was about to say the datasheet I have for the '166 seems to indicate that when you hold "clear" the output at Qh is low, so that shouldn't really be any different than if clear isn't held low and the '166 is happily running along clocking out the low states it's getting from pin 1 being grounded, but... in the kaypro I assume the problem is you're still getting the "load" pin toggled and loading random memory contents even when you're out of the active video area, so you're pulling "clear" to squelch that.
    (Would it be any more efficient to make the shift register load switchable on/and/off by the GAL instead of manipulating clear? I guess it probably wouldn't make much difference. At least the takeaway is my scheme should be fine as long as I'm only generating load signals in the active area.)
    I was wondering about the less-than-8-bits thing because I'm thinking of trying to do a VGA output version, but because of the limits on how fast I can clock the CPU I'm using instead of a discrete timing chain I might have to do six bit wide characters instead of eight. (Right now I'm doing a 512x192 effective pixel area on composite with the 12mhz clock, I was thinking with a 20mhz clock, which is the limit without overclocking, I could do 384x192 (triple-scanned) using the exact VESA timings for 800x600@60hz, which uses a 40mhz clock.) I'll need to reprogram the GAL magic that generates the loads to reset the counter at six bit intervals instead of free-running and just rolling over...
    Yeah, I can definitely see why the home computer makers loved the 6502 so much. Slave the CPU to the pixel clock and the job's done for you. Alas I'm more interested in this phase targeting S-100 and TRS-80-like Z-80 applications.
    Yeah, I was trying to think at one point if a scheme like that with latches really helped me, but I keep getting stuck on the fact that while you might be able to use one to make *writes* synchronous you're boned when the CPU wants to read from memory; either you take the glitch or you need to generate wait states because you won't be able to preload a read latch for when the CPU request comes in.
    Since the TRS-80 is one of my design inspirations I was looking at how the Model III de-glitched its display (the Model I didn't), and if I understand its service manual correctly it basically has logic to pull down the WAIT signal for the Z80 if video RAM is accessed outside of a blanking area and holds it until it goes into blank. Worst case that would halt the CPU for 64 character's worth of video output. (IE, it looks like it makes no attempt to make the access hold any more granular than that.) If that's a legit way to go that's easy, I could just implement similar logic that defines "not in blank" by that line that lets the load counter in the GAL run. It does seem like there should be a "smarter" way to do it, though, definitely.
    (Ultimately maybe I don't care about video glitch artifacts as long as I can actually make the memory read/writes reliable, but glitch free would be "nice".)
    Here's a picture of the video output from mine as it stands. I just this week solved a problem with another function I had the GAL for, which was a selectable 2:1 clock divider for the pixel clock so I could do both "high" and low-res modes in hardware. (512 vs 256 pixel; the TRS-80 and some of the S-100 cards I want to be able to emulate had 32 column modes.) Shows high and low res alternately running with the same source bitmap. (With the lower res I can move a 32 bytes "viewport" around on a 64 byte line by adjusting counter offsets.)
