Results 1 to 9 of 9
Thread: Issues with Gateway 2000 P4D-66 desktop PC
    Question Issues with Gateway 2000 P4D-66 desktop PC
    So I just today got my hands on this lovely 486 based gateway desktop PC. I'm having 2 major problems. It's having these two IRQ errors (as pictured) as well as I am unable to get a hard drive to work with the system. Any help would be appreciated
    6,909
    At the top of the photo, I can make out, 'Real time clock error'. Any other errors not in the photo?
    The Internet indicates that the P4D-66's motherboard has a Dallas RTC module, one that contains a battery. The web page at [here] suggests that if the RTC module's battery is discharged enough, a battery error is displayed. Seeing a battery error?
    Yeah it's realtime clock battery is dead dead. It won't hold the time for even a restart. How would I get a new one though?
    4,839
    You could find a replacement Dallas RTC but many have been sitting in warehouses for a long time leading to having mostly discharged batteries. Check which model is on the motherboard. The supplier I would often buy such from indicates it should cost about $10.
    The other option is to carefully cut open the plastic shell and solder a new battery to replace the failed one. An example of how to do it is at https://classic-computers.org.nz/blo...ttery-chip.htm
    Ill go over and check the model in a little while. However none of this explains how to get it to detect a HDD
    6,909
    Quote Originally Posted by Alabamarebel1861 View Post
    A lot of people think, "If the CMOS battery is dead, all that means is the CMOS SETUP (and clock) information will be lost when I turn off the computer. So if I keep the computer powered on, I should be able to setup/configure the CMOS SETUP and get the computer going."
    For some motherboards, that is not the case. One example (of a few) is at [here]. It is possible that you may need to replace the Dallas module (or replace its battery) before you can proceed further.
    I've noticed that the IDE controller defaults to off. When I try to turn it on and restart it turns itself off again. This is even the case when all other modified settings were successfully saved. Does that still sound like a dead battery case?
    6,909
    Taken in isolation, no, but we have seen some pretty weird stuff over the years. Factor in other symptoms such as "It won't hold the time for even a restart." and a 'Real time clock error' message being displayed, fingers start pointing at the Dallas RTC/CMOS module (and supporting circuitry).
    Oct 2020
    Northeastern US
    19
    To add on to this, I recently (2 years ago) got a replacement RTC for my 486 from Digi-key
    https://www.digikey.com/en/products/...DS12887/956874
    They also have one with a C in the model number, but that stores four digit years and I don't know how that would interact with motherboards of this vintage
