Results 1 to 4 of 4
Thread: Macintosh II Speaker and Audio Output Jack
    Default Macintosh II Speaker and Audio Output Jack
    Greetings All !!
    I finally finished restoring a Macintosh II logic board and all is working great. All except the internal speaker. I got zero audio from the speaker. The audio output jack works but only one channel ? I wasn't sure if this is a mono output or stereo output ? I thought I read online somewhere that it's a stereo output, but can't find that article anymore. Can someone let me know ? Also, if it is stereo, I believe I have a bad channel. Would like to know where the sound chip and DAC is located or anything else I can look at ? The jack tested fine as when there is no connector inserted, I get continuity to the speaker jack.
    Thanks !!
    MaCJaX
    I think the Mac LC line was the first to have stereo sound.
    Anyway, my Performa 475 has exactly the same issue: output jack works fine, but the internal speaker stays silent.
    It looks like there is 2 Apple Sound chips associated with this, right next to the speaker terminal. I am having problems figuring out which sound chip is for which side (left or right). It looks the right channel is also shared with the internal speaker. I have a few extra sound chips if you want one for your Performa. Let me know ..
    Just an FYI for whoever has the same issue. I was able to fix. I had 2 issues. 1st issue was a bad trace from C5 (positive lead) to U14 pin 15. The other was a bad U15 IC. Fixed trace and replaced IC and she's working !! Thanks all !!
