Results 1 to 9 of 9
Thread: Wanted Trsdos 2.8DD (Percom) Please
    May 2013
    Williamstown Victoria Australia
    424
    Default Wanted Trsdos 2.8DD (Percom) Please
    Hi All
    DSK, HFE .
    Just wanted to see how it works.
    Thanks
    Keep Safe
    Ray
    If it ain't Broke then PLEASE DONT fix it.
    Procrastinators Unite.
    I keep telling you I am Not Pedantic.
    Mar 2013
    Chaffee, MO
    1,607
    Ray,
    Give me a bit to locate it on the server and convert.
    Larry
    Mar 2013
    Chaffee, MO
    1,607
    Ray,
    The copy that I've located is for the Model 1, and is the Radio Shack Adapter. I don't see anything
    for the Percom. My old Model 1 used the Aerocomp Floppy Disk Controller Board.
    Is this what you are looking for?
    Larry
    Mar 2013
    Chaffee, MO
    1,607
    Ray,
    I've got your files processed and they are 35 Track Single Sided, Double Density. I've got a *.fpf
    floppy configuration file and the *.hfe files. Also created the *.RAW (Sector Dumps) while I was at it.
    Send me a PM with your Email Address. I'm not sure I know which contact you are.
    Larry
    Mar 2013
    Chaffee, MO
    1,607
    Ray,
    Your *.HFE files are on the way.
    Let us know how it goes.
    Larry
    May 2013
    424
    Hi Larry
    Thanks
    I have sent you an Email
    Keep Safe
    Ray
    May 2013
    424
    Hi All
    Still wanting a copy of TrsDos 2.8dd (Percom) for a Model 1
    Keep Safe
    Ray
    I only have 2.7 Percom and 2.8 RS Doubler. Its really not much difference between the RS and Pecom doubler just how it flips double on and off so finding the changes that were patched to 2.7 should be able to adapt to 2.8. If I rememebr right the RS double needed an extra step in the driver that can be patched around.
    I had started the work to do this, then I located an RS doubler, and abandoned it.
    I dont recall what the differences between 2.7 and 2.8 were but 2.8 felt more polished.
    May 2013
    424
    Hi Tibs
    Thanks for the info.
    Surely somebody has done the patches.
    Thanks anyway
    Keep Safe
    Ray
