Thread: Linux support for C-H trackballs.
    35,315
    Default Linux support for C-H trackballs.
    Here's a strange one.
    I have two C-H Trackball Pro devices; one PS/2 interface and the other serial.
    If I use either and boot Windows 95-Win7, the trackballs are recognized and function as they should. I'm using a PS/2 interface keyboard, FWIW.
    If I boot any version of Linux from about 10.04 on (I haven't tried earlier ones), Linux is blind to both devices. If I plug the PS/2 one into a USB converter, everything is fine and Linux has no issues.
    Can anyone shed any light on this connundrum?
    For serial mice you'd need to do something like "inputattach --microsoft /dev/ttyS0" where /dev/ttyS0 is your serial port (whichever it goes under). As for the PS/2 port, that's an odd one, it should just work.
    35,315
    Apparently you can also edit the xorg.conf file, but in Debian Squeeze, I can't find it--it's definitely not in /etc/X11.
    I guess I'll have to run Xorg --configure to get it. Strange that it wasn't part of the installation.
    (This is an old K6-2 500 system, so I'm somewhat limited on OS choices).
    35,315
    I tried the xorg.conf modification and it did nothing. Online documentation seems to imply that this method is deprecated. Okay...
    I'm running Debian Squeeze on this system. "inputattach" is not a package installed by default; so it's "sudo apt-get install inputattach" first. Edited the rc.local to include "inputattach --daemon --microsoft /dev/ttyS0", reboot and all is well.
    I'm glad inputattach worked. Yea, the xorg.conf setting is well deprecated. I wasn't sure which distro you were using but I'm glad the guess worked.
