Originally Posted by
Eudimorphodon
Assuming they're both 12" tubes (which I *think* they were?) then the chances are at least "fair" they're compatible; a company called Langley St. Claire sold replacement tubes in green/amber/etc. for the TRS-80 Model I and III and the same tubes were also listed as compatible with a fair slew of other machines.
(That said, you might want to at least make a token attempt to make sure there isn't a Model 2000 owner that needs a monitor before you strip it, since the choice of monitors for those machines is drastically limited compared to what will work on your Model I.)
It blows my mind to see what people are asking for old Apple monochrome monitors (Specifically the "Monitor //" and "Monitor III", which used to be *dirt common* to the point that it was hard to give one away) on eBay. I was about to recommend one of those as a solid choice for a composite green monitor you might be able to scrape up cheaply, but, no, I guess not anymore.
