Are there any good troubleshooting steps for the Model F Keyboard's electronics? I've been given one with unknown history that appears to be broken.
I've disassembled it to deal with corrosion on the top and bottom plates and right now, i've got the bare pcb on the bench. I've plugged it into an arduino running a program which is outputting the keyboard data line to the serial port. I know this program works because I have plugged my functioning model F and that does what I expect (passes BAT and sits quiet unless I press keys and then I get the keycodes)
This particular board, the BAT is always failing with a different byte code and there is always data on the data line like many keys are constantly depressed.
Any pointers or should I just give up?
The keyboard would clean up nice otherwise.
