Thanks for your input T-Squared!
The bookmark icon vanished. I noticed that ribbon cable for floppy drive was loose. some pins maybe contacted wrong places there. I corrected
it and no more bookmark icon. I have to find out a way to attach that ribbon cable well. Originally it is pressed down and hold in place by tiny
plastic clip. I knew when I tried to open it, that this will break very easily. tried very carefully pry it open knowing that and it broke anyway.
Perhaps, if the plastic was new it was possible to open without breaking, but the old plastic is extremely brittle and for me not possible to open without breaking it.
About the cable pads... in my previous post I attached 6.jpg. In that upper corner there is definitely some sort of corrosion going on.
It looks like maybe someone did try to fix that earlier. Is this part the 'pad' you are referring to ?
