Results 1 to 10 of 15
Thread: Booting IBM PC from vinyl
    Oct 2014
    near frankfurt/m, germany
    1,126
    Default Booting IBM PC from vinyl
    4,864
    I like it even if the utility is fairly limited.
    Waiting for the wire-recorder version...
    35,720
    Well, I suspect that the floppy disc version might be a possibility...
    6,988
    Used a custom boot rom. I'd be more impressed if they'd keyed in a program in Cassette BASIC.
    Outer Mongolia
    3,231
    Or just “load”-ed one. I mean, yeah, you have BASIC, use it.
    6,988
    LOL, yeah
    San Antonio, TX
    377
    Ye dang fools, ah was bootin' mah IBM PC offa telegraph befer ye's were in diapers!
    B.. but you're only 30 years ol--
    SHADDAP!
    4,864
    Retrohun did the boot into a game loaded via the cassette port almost 3 years ago. J.R. Bogin did it though a ROM design but nothing really precludes someone who wanted to from taking the two projects and merging them to make a cassette loaded program that in turn loads a DOS from cassette into what is effectively a RAM disk and then boots that DOS. The design does seem to need a very substantially upgraded 5150; this is not going to turn into a viable solution for a 64K 5150.
    I don't understand why each variation on the theme uses a different audio device attached to the erstwhile cassette port. Is there some contest going on?
    I even didn't know that such a thing existed! Nice to know. Thank you for showing it to us.
    www.baltissen.org
