Originally Posted by
Chuck(G)
Believe it or not, floppy disk centering was a big deal back in the day. When the first 5.25" drives came out with DC controllable spindle motors, there was a huge problem with disk insertion when the motor wasn't running. Eventually, a switch was added to detect the drive door closing to give the motor a short period of spin so that the hub clamp could center the floppy. The 8" world at the time, didn't have to deal with this as most drives used line-operated motors that were always on.
So do check your drive to make sure that the spindle motor is running as you insert the floppy.
