Hard drive only partially accessible
Dell model System 200, a big horizontal beige metal box, 286.
I am trying to get an old hard drive working to use it as a drive D. It is a Seagate ST-225, 21 MB. According to redhill.net.au, this is a type 2 hard drive. I have checked that the jumpers on the hard drive are correct. The hard drive is plugged into both the controller ribbon cable and the data ribbon cable.
I have to boot from an old DOS 6.20 boot floppy. The modern DOS 6.22 floppy I made will not work in this computer for some reason. The boot up process always says "Hard disk failure." I can continue the boot process and from the DOS prompt, I can switch to C:. I can do a dir command in some directories but not in others. I can read certain files but not others. The two errors I keep getting are "Sector not found reading drive C" and "Data error reading drive C."
I had enough room on the old DOS 6.20 boot floppy to copy IDESDI.EXE onto it. Using IDESDI.EXE results in "An AT controller was found. Memory allocation error. Cannot load COMMAND, system halted."
Using ScanDisk on my DOS 6.20 boot disk results in "ScanDisk encountered a data error while reading the FAT on drive C. This error prevents ScanDisk from fixing the drive."
I know that the FAT is the file allocation table, where the filenames and their locations are indexed on the disk. I am hoping that the FAT is not corrupt and I am just doing something not quite right.
Sattinger’s Law: “It works better if you plug it in.” 🤯
Corollary: “It works even better if you plug it in correctly.” 🤯🤯
