Hey all. Recently got a free 5160 out of an abandoned storage unit. All stock with 512K of ram, original 10mb IBM hard drive and IBM 5.25" floppy drive. The hard drive works, and after a little work, the floppy drive now works as well. When I got it home, it would boot from the hard drive, and then after a while, the allocation table was corrupted, but it'd still boot.
It started being iffy, so I formatted the hard drive (was mostly full of old wordperfect documents, nothing else of interest) and did a fresh, successful install of IBM DOS 5.0, which I use on quite a few of my old XT class machines.
However now it's developed a condition where if you turn on or reset the computer, it does the ram test, checks the floppy drive, and then the HDD light flashes for a split second and instantly reboots. The C: drive still works fine and is recognized if you boot from floppy, all files are accessible, seems to be plenty healthy, it just refuses to boot from it for whatever reason. Sometimes after this, the floppy light will be on and it'll seem to seek indefinitely, sometimes it does a test and stops. I am getting no startup errors. Successful ram test and then it does this.
Board dipswitch settings are correct and have not been altered.
Any idea what my next step would be to get it booting from the hard drive again? It should theoretically be able to no problem, it just doesn't seem to want to.
Thanks!
