Results 1 to 10 of 13
Thread: "Technical Solutions" EPROM emulator asisstance? :-)
    Nov 2016
    Muskego, Wisconsin
    30
    Default "Technical Solutions" EPROM emulator asisstance? :-)
    Hello,
    In my continuing quest to bring my 1980's computer equipment back to life, I'd like to
    employ my "Technical Solutions" EPROM emulator.
    I really liked how simply it worked .. You'd plug the emulator into your EPROM socket
    of your target board, and run a RJ-11 cable from the emulator to an adapter that plugged
    into an unused printer port.
    The software utility let you chose what file and type to upload, and away you'd go
    I still have the emulator, software and manual. What I do NOT have is the
    interconnecting cable and printer port to RJ-11 cable adapter.
    I have some "shells" that have a DB-25 and RJ-11 cable connector, but I've no clue as to
    how to wire it
    Can anyone help? Perhaps a wiring schematic for the adapter? Or an "old" Technical
    Solutions emulator or parts they'd care to sell?
    Copious thanks!
    Mar 2013
    Chaffee, MO
    1,657
    Sounds like an interesting project.
    The IBM PC Parallel port is described at this URL: https://pinouts.ru/ParallelPorts/Par...C_pinout.shtml
    Pin 	Name 	Dir 	Description
    1 	/STROBE 	--> 	Strobe
    2 	D0 	--> 	Data Bit 0
    3 	D1 	--> 	Data Bit 1
    4 	D2 	--> 	Data Bit 2
    5 	D3 	--> 	Data Bit 3
    6 	D4 	--> 	Data Bit 4
    7 	D5 	--> 	Data Bit 5
    8 	D6 	--> 	Data Bit 6
    9 	D7 	--> 	Data Bit 7
    10 	/ACK 	<-- 	Acknowledge
    11 	BUSY 	<-- 	Busy
    12 	PE 	<-- 	Paper End
    13 	SEL 	<-- 	Select
    14 	/AUTOFD 	--> 	Autofeed
    15 	/ERROR 	<-- 	Error
    16 	/INIT 	--> 	Initialize
    17 	/SELIN 	--> 	Select In
    Using Pins (2..9) = D{0..7} it shouldn't be hard to get the 8 bits sent over the RJ-11's 8 wires
    to D{0..7} in the EPROM Emulator. D{0..7} should be wired to the RJ-11 Port on
    the EPROM Emulator from it's internal RAM.
    Once you have that figured out you could make a PCB (if needed) or just wire
    the Parallel Cable accordingly.
    Larry
    Sure it wasn't the serial/com port ?
    I tried searching for "Technical Solutions EPROM emulator" but the terms are too common...
    (just as when I tried to find info on my Data Display LED sign.....)
    Maybe a picture of the emulator board can help ?
    Outer Mongolia
    3,230
    Quote Originally Posted by gertk View Post
    I second that, given the fact that an "RJ-11" plug has a maximum of six contact wires. (Technically it's called "RJ-11,14, or 25 depending on how many pairs are used.) It's still possible it bitbangs over the parallel port but the communication would pretty much have to be serial.
    Mar 2013
    Chaffee, MO
    1,657
    I bet it is a RJ-45 connector and what you need is something like this:
    https://www.cableleader.com/adapters...5-to-rj45.html
    That would be the best way to go. You can make any length CAT6 cable with Stranded or Solid
    conductors by crimping on the ends.
    Larry
    Nov 2016
    Muskego, Wisconsin
    30
    I have some photographs of the emulator but I'm having trouble posting them here
    Is a 100K jpg OK to post?
    35,705
    Probably not, I think 80K is the limit (unless it's been changed). Use an off-site hosting service like Imgur.com and link to the images in your post. You then can go as huge as you want.
    Nov 2016
    Muskego, Wisconsin
    30
    Let's see if this works ..
    [IMG]www.bignick.net/emulator1.jpg[/IMG]
    35,705
    Get a 404 on your image url.
    Mar 2016
    Georgia, USA
    685
    The manual defonitely says it was a parallel port connection.
